Hey folks,
So, I went ahead and dug I to the stereo over the past couple days and replaced my non-nav radio setup with an alpine ilx-107. Overall, the install went smooth and all functionality is there. I also installed the micro bypass and ASWC module to retain steering wheel volume controls. All functioning well.
The trouble started with the reverse camera. I can’t get the right wiring configuration to trigger the camera to prioritize the signal and show the video in reverse. The camera has power in reverse and powers up when the rear lights get juice. I can verify that when I manually toggle the camera on. What I don’t know for certain is what wire I need to tap into the trigger the signal in reverse. Anyone know for certain?
My brother has a camera setup in his GX, and his works as it should. We basically mimicked the plumbing for wires and traced he lead back to the driver’s side kickplate side and tapped into a red with black wire in that huge wiring harness down by the driver’s left foot. All looked right, except the mystery remains unsolved...
Can anyone verify the connections i need between the alpine and the GX to trigger the reverse cam? What output wire needs to connect to the reverse wire I ran to the kickplate? Also, there’s a red lead wire attached to the RCA wire that I’m left Scratching my head over...does that get left capped, or actually connect to another wire?
sorry if this sound vague, but in lieu of pics it’s hard to explain. Thanks in advance for the help.
