need clutch pedal support bracket
I need a clutch pedal support bracket PN 55107-89102 for a 80-83 hilux. Does anyone know of a source for new or used part? Mine developed a crack and I had it welded but has broken again. Thanks
Interesting. My 1982 did that too after I installed a HD clutch. I bolted through the top.
Rancho did not have anything 80-83. Pappy, what do you mean "bolted through the top"?
Keep in mind this was 3 decades ago. As I recall I bolted through the clutch bracket up behind the gauge cluster.
I had the same problem, welded it up and then put a bolt through it.
