GTV
Could be literally dozens of different things. Scan it.
@NeedaLX, what Kabanchik said is pure gold. I never got this kind of advice from LC/LX guys who I got advice from. They all said -"Easy peasy ownership." "Zero to no upkeep. Regular maintenance and hit the trails!".Solid advice. I am definitely looking for newer models primarily and ideally hoping to hold out for a 06-07 model. But yeah, even the premium on those doesn’t guarantee they still won’t need $5k+. But the way I see it, the newer every component is the better
I know the 100 series are somewhat fussier but I had a similar mindset when shopping for my LS430 several years ago. Was able to find a southern 1 owner vehicle. Lexus dealer maintained for most of its life. Needed some minor things but not too much in deferred maintenance
Well.... HaveaLX
Purchased a 2006 with 92,000 miles, bone stock, clean frame, and generally flawless inside and out. Flew out to pick it up and promptly drove 900 miles home against better judgement
Not a fun drive but it handled it like a champ. Very pleased with the comfort and smoothness of the AHC. The power of the VVT felt adequate and managed a modest 19 mpg cruising at 70
It's not clear when the timing belt was last serviced (if ever), so that will be the first thing on the list, along with AHC service, and the rest of the 90k mile items. Also need to add a Gromm unit ASAP
Overall very pleased with it and happy to be finished with the search
The one thing that did come up on the drive..
ABS, vsc trac, and vsc off lights came on after several hundred miles. The first time was after stopping/slowing down after several hours of driving
The last half of the trip the lights would go on/off intermittently after applying brakes and coming to a full stop. Brake performance felt fine to me, no unusual brake characteristics from what I could tell
Any thoughts on this? I know these have some common/potentially $ brake booster/master issues. Hoping it is something simple like a sensor
I guess this is my first 100 series forum research/troubleshooting topic...![]()
Connect terminals Tc and E1 of Check Connector (in engine bay) and remove the short pin (normally inserted in bottom right corner).Some additional info on this procedure:
View attachment 67929View attachment 67930View attachment 67931
Also, can you expect 14MPGs out of a 100 series? With skimpy, zero rolling resistance tires and a lot of wishing upon a star...maybe. I have seen 14 out of mine on a highway, in town I don't even get 9. Would I have any other vehicle than my Bertha, maybe a 570 but that's it. I love my plump gal too much.
Congratulations and enjoy it in good health.
Best approach is always use a scanner to understand the code/s and start from there. Could be as simple as the ABS sensor/s being dirty/needs servicing, and hopefully is a simple fix.
No, if it's in LOW, it'll stay in low until you start driving. Not sure but I think it's around 10 MPH that it automatically comes back up.Question regarding the AHC and overhead clearance
At the moment I’m not sure whether the LX will fit in my garage without modification to the hinge of the garage door (hangs down too low when garage door is open, clearance isn’t an issue with door closed)
It’s either going to fit or not fit by a matter of millimeters given the stock height dimension of the LX. It will fit for sure however with the AHC set to LOW
Is there any potential risk with driving in and out of the garage in LOW mode? How long does it take the vehicle to raise up once moving? Or does it only raise once you reach a certain speed?
And when the vehicle is parked in LOW it doesn’t automatically raise back up after the vehicle is turned off, correct?
I’m still dying on my 03-05 sword, you get the 5 speed & the much simpler non-VVTI. I also prefer the old cheap bulbs instead of LED tails.Yeah, I don't want to settle and plan on keeping this vehicle long term
Which begs the question... that I'm sure has been discussed on here countless times
Wanting a newer model for primarily on-road use - should I truly hold out for a 06-07? Or be open to 05s too?
I've only driven 4-spd, pre-vvti upgrade years, so can't say how much the power increase is worthwhile. Definitely want the 5-spd
Congrats on the score! Looks great.
If you don’t pound highway miles, a 4 speed is also a great score for price. The 06-07 unicorns just aren’t worth it imo. It’s still a truck to me, not an investment.
Congratulations, looks super clean inside and out, nice find!
Congrats man nice find! I snagged my '06 late last year. I likely overpaid a bit for a cosmetically tired but incredibly rust free SC rig w/ 208k. But was coming from such a rusty rig previously that I was dead set on finding some ac lines and a rear cross member I could eat off of. Seems like you scored a unicorn!Thanks! The only negative I can point to so far is that it now has me considering whether I need to replace my LS with one this clean
For two vehicles roughly the same age and mileage, complete opposite body and paint conditions
Somewhat ironic given their intended uses...
Prepare to spend about 10X more on gas over your Accord if you’re gonna daily an LX. Welcome !
10x? So is the Accord getting 150 mpg?
keep in mind the VVTI engines are few and far between.. I like buy 2001... look at u-tuber "the carcare nut" ... he is starting to see head gaskets deteriorate, etc. he has seen later ones get scrapped when used VVTI engines cannot be found if needed.. 98-2001 are simpler. parts everywhere. no Nav. so easy to upgrade stereo.. I do like the 4 speed in it. .. it is a cruiser.. it goes everywhere great smoothly at its own pace. I think 00-01 are the best year as No-Nav and A-Trac standard. as well as as 4 pinion front diff.
These things are gas hogs. You’re literally putting in around 20-25 gallons for every 200 miles you drive. Gotta be slightly insane to daily one of these.10x? So is the Accord getting 150 mpg?
