I have a new pre 69 master from a fj55 that I am using for a clutch slave on a V8 conversion.
Using the brake master with the larger bore than the slave gives me more throw
for my conversion. Mark whatley set me up with this idea and I have been satisfied for 2 years now using it.
My problem is my brake master started leaking so I purchase this oem pre 69 master and the end fitting is different.
My old 55 master used a compression setup which was fine for the clutch but not what I wanted. I now want to go double flare with the proper fitting for the new master as seen in the pic.
Can someone give me the correct size of this fitting and where I might find one?
thanks
thanks
