Need 1HD-FT SST 09992-00400
Closure. I ended up with a SnapOn M3585 tool, and Georg made a minor adjustment. Now looking forward to getting some compression numbers.
Sorry to bring a dead thread back. I too couldn't get the factory tools.
Can you run us by your test setup please. I need to order these parts from the US it looks like.
The SnapOn tool can be bought on eBay from time to time. Grinding off some of the tool makes it work on the 1HD-FT just like the Mr. T tool.
I’m surprised to see so little info about this tool. Is there something I’m missing?
I got it from Japan4x4.
Cheers
Want to rent it out? 107,640 Yen purchase price from Dave is pretty tough considering I hopefully won't need it very often/ long.
euclid, I warned you. And I also told you you would probably not need it :)
If I was closer I would lend you mine.
I have heard of guys making one out of an old injection nozzle. But for me, since I did not have a specific engine in mind, I just got the full kit. From B to 1HD-FTE it has worked flawlessly.
anyone here had success modifying that snap on tool for use in the injectors on a 1hdfte?
The snap on M3585 is for a cummins C 8.3L which uses a 17mm diameter injector
With a little digging you should be able to find a similar on for that application or possibly a yanmar marine diesel application. The ones below are all cummins C series adapters
the last one can be picked up on amazon, u might just order one and take some measurements... u can always return it if its wrong... Or try calling a few of these companies (the one in australia would probably know what fits).
the snapon one looks like it can be found on ebay from sporadically
