so not to long back i upgraded my sound system, amp, speakers, and sub, they bypassed the OEM amp in order to keep my Nav all happy. So today it is raining like a bitch outside and i see water seeping in through my sunroof. I figured my drains were plugged and i'll clean them out. I also noticed the floorboards were wet on the PS and it seemed water was dripping on my left foot while driving as well.
my Nav works like normal but when i hit the climate button it says "check connection to Air Conditioner" and it also doesn't display my outside temp either. i get it home and search for my stinking air compressor so i can blow out the drain holes. finally found it and cleaned it all out. I also took my neg battery cable off for 15min so the ECU would reset as well.
all finished. turn my truck on and it works like it should. then i start to go though the buttons and then go back to climate and it does it again.
what do you think the most likely culprit is, the sound system or the water? or is it something else? i had the front glass changed about 5 months ago as well....
