Yes you read it right!
"Mystery repeated engine failure that disappears!"
You got to read this whole true story! It is so unreal at the same totally the facts! I'm completely puzzled!
We all know a 2F is rigid but certainly cannot heal itself.
I have encountered most bizarre fatal sounding engine failures in the last 9 months that disappeared again. Yes, you read it right again "disappear.."
December 18 2012 ~ 4pm
A normal day, all is fine, coasting slowly to a stop at an intersection the engine starts knocking nasty as if I whack a hammer at the block; tack, tack, tack.... The engine shakes, vacuum is ~ 4-5in/Hg lower from the normal ~ 20in/Hg I have. Cylinder 5 shows no change response with simple spark plug wire on/off test.
@#$%%^&*! I verbalized loudly...
My guess was, her time has come at 330k miles...
I stop, shut off ignition and think. Maybe I make it home driving slow on the freeway in 5th gear. Otherwise it's AAA flatbed.
After a few minutes I start her up, the 2F starts up and shakes tack, tack, tack... I noticed that during cranking you hear no knock.
I rev her up a little and the nasty sound fades little by little.
Slowly I crawl with 40mph home on the freeway. While driving I notice the knock has faded more and more and the vacuum returns to normal. (I have permanent a gauge installed)
Arriving at home all sounds hunky dory like nothing ever happened and she purrs!
WTF?
I rev her up take her for a spin, all is well and perfect! Hmm..
Compression check is acceptable on all with variance 150 - 160 psi. No blue smoke.
...12,000 miles later... ..and three oil/filter changes:
July 19th 2013
Smog check, pass all stellar. Tech guy says "Wow she runs really nice and clean..., the engine runs smooth too".
Yes.
July 21, 2013 ~ 3pm
I roll into a parking lot, engine idling suddenly a tack, tack, tack engine sound fades in! The 2F shakes. Cylinder 6 fails the simple spark plug wire on/off test.
Ohh FTSA! Ohh MF'r, this is it I think.
I rev'd her up twice gently to about and no more than 1,500rpm...
...and then...
Yup!
Sound gone! Engine runs normal again!
Vacuum good, exhaust steady. A classic S.N.A.F.U?
Ah WTF, I'll keep going.
Driving her home I noticed she runs actually damn well, responsive powerful and all.
At home compression check, all acceptable! WTFF is going on?
So I go, keep driving around. I notice she runs really runs exceptionally well, better than ever. Reasonable good mileage (16mpg), very good power and responsiveness, 1qt oil per ~1.5k, no blue smoke, no nasty sound, etc. SNAFU again?
Yesterday Aug. 09 2013 I came home from 1 1/2 hour freeway trip going average 55 - 65 mph, all well and humming.
Before I turned her off I mildly rev'd her a couple of times to listen how smooth and solid she sounded. Great. I listen to her idle purr. Perfect. ignition off.
Good night, sleep well.
August 10, 2013 343,4xx miles
(~14,000 miles later since December '12)
This morning, less than 12 hours ago from my previous arrival, I go at 7:30am and started her up...
Tack, tack, tack.... MF, WTF now?
Rev'd her up twice....
Guess what?
Sound almost gone! Runs almost fine again!
WHAT IS GOING ON? Please, you tell me! I'm lost!
The only thing I can conclude is a random stuck open intake or more likely exhaust valve getting hit by the upcoming cylinder top until the latter knocks it back into action. Is this a know issue?
Or what else could it be?
WTF?
July 19th 2013
Yes.
July 21, 2013 ~ 3pm
...and then...
Yup!
Guess what?
