My "Too Many Specs" Trailer Build
Hi. I'm a friend of J-Man in real life (have several loose tooth fillings from Baja surf trips with that guy) and I'm doing a trailer build and he said this board was the place to find fellow enthusiasts.
So here we go:
I have an Eezi-Awn RTT that I bought because J-Man has one and we'd used it all over southern California and deep into Baja. In my book, definitely the way to go.
Craigslist yielded an inexpensive used shell for my 01 tacoma, and I fabbed up a simple internal frame for the shell itself and mounted the tent to the top of the shell. I have an overhead hoist to haul the shell+tent off the truck and chains hanging from the ceiling of my shop to secure it in place. That all works well but my biggest gripe is that with the tent on my truck, once I reach camp, I'm stuck. Obviously I can't go anywhere without completely breaking camp. I put up with that for a couple years and then finally decided to do something about it.
I go to the desert quite a bit during the season and had acquired 3 quads plus a tandem axle trailer to haul those plus all my camping gear. It worked pretty well, lower shell onto truck, bolt it up, hitch up trailer and go...but the trailer is on it's own lift up and out of the way so that was the first thing that had to go. Sold, for $100 less than I paid for it 5 years ago. God bless Craigslist.
One of the quads had been my ex-wife's and seeing that thing reminded me of that miserable tart...so that was the next to go. Out of sight, out of mind.
Next up: Specifications and criteria for the build.
specs
I spent a couple days on offroad forums, checking out all the cool builds, seeing what works and what doesn't and thought long and hard about this build before doing anything. Here's my list of requirements and specs in no particular order.
Trailer has to fit on my storage lift with both remaining quads adjacent to it. Therefore, it can be a maximum of 9 feet long.
In order to get the best possible gas mileage, the overall height including RTT and storage rack can be no more than 6 feet which is the height of the cab of my Tacoma.
Maximum height with fully compressed suspension 69 inches, in order to clearance the ceiling when on the lift with the lift fully elevated.
Height of tent to be low enough that I can remove the cover and set it up without having to climb on the trailer.
Height of bottom of tent when opened to be no less than 6'5". I'm 6'2" and wearing hiking boots on rough terrain, I just want to be able to walk under the tent overhang without whacking my head.
(these two seem to be contradictory, but I have a solution.)
Flat topped squarish wheelwells able to be stood upon in case I do need to get up on top.
12V refrigerator/freezer. No more dealing with ice. I have a small fridge that runs on propane and without ice taking up a bunch of space and ruining everything, I was able to take food for myself and a girlfriend on a baja surf trip for something like 8 days. With a serious 12V fridge with a compressor, I can dispense with propane altogether.
Trailer to have track of 69", same as the truck so where the truck can go, trailer can go. Also this is the minimum width to fit on the lift.
Wheels and tires the same as those on the truck, for aesthetics and practicality. BFG TAKOs on 6x5.5 sequoia wheels means I only need to carry a single spare for 6 wheels.
Suspension utilizing independent trailing arms, airbags, shocks and bumpstops. Independent arms to be able to go 80MPH down the North Road to Scorpion Bay in Baja, bumpstops in case a bag fails, I want to be able to keep going albeit more slowly.
Integrated water and fuel storage to save on schlepping bulky cans back and forth. Store 20 gallons of water and 15 gallons of fuel.
Integrated compressed air storage.
12V and 110 electrical supply.
Electric brakes so the trailer doesn't pass me on a slippery slope.
Surfboard storage.
Serious trailer levelers so the thing will be super stable even when not connected to the truck.
Weight down low and forward.
Multiaxis coupler.
Good looks and badass functionality.
That's about all for now. Build pictures coming next.
plans
After thinking about all this, I downloaded Google Sketchup. What a great program, especially for the price. With this I designed the trailing arms and the rudiments of the frame, and then figured out where the fridge would go, etc. Of course not everything is coming out exactly to plan as you make adjustments as you go, but overall I'd recommend that program to anyone taking on something like this. Three angles:
D727411_057109_963866
D727411_057109_963869
D727411_057109_963862
frame layout
The frame is made out of 2x3 steel. I have a buddy who works at a metal supply so i get a decent price on this stuff. My idea is to use the frame itself as air storage. By my calculations, the sealed frame will have an internal volume of 2500 cubic inches, or almost 11 gallons. Pump that up to 8-10 atmospheres and you've got a decent amount of stored energy and no need to carry a separate 2 gallon air storage tank. Plus, the strength walls of the frame greatly exceed anything you'd see in a low-pressure storage tank. The only difficult part is sealing up all the welds pressurized-air-tight. Easier said than done.
D727411_057109_963679
Wheels I found on Craigslist, had to pay 325 for 4 and only needed 2...but I sold 1 already for $100 and the other one will sell in time. Also, I thought I might use these coil spring I had lying around, but then chose airbags instead once I figured out I'd want the adjustability to fit the trailer on the lift.
D727411_057109_963666
Here's most of the frame welded together. It took some time to perforate the crosspieces and get everything lined up but it turned out pretty good. I think.
D727411_057109_963685
For the tongue, i was originally going to work with a standard triangle. But then I found a pretty decent tongue box on sale at harbor freight and decided to use it. I always say if you can't build it better or cheaper, you might as well buy it. But to attain the exact angle necessitated a widening of the tongue, hence the additional pieces you see at the front of the trailer frame.
Here's a couple shots of where the box will mount on the frame:
D727411_057109_963664
D727411_057109_963677
The box will hold the deep cycle battery and inverters and a few other odds and ends I'm certain.
speaking of harbor freight-they also had a 1000 lb capacity swingaway jack for 24 bucks, and a pretty heavy duty all terrain tire on sale so I bought them both, cut off the dinky trailer jack wheel and welded on a bracket holding the allterrain tire.
Yes, I am a nerd.
D727411_057109_963669
frame plus arms and wheels.
To make fabrication a little easier, I managed to find 6x 5.5 hubs with electric brakes already setup for a square axle instead of round. 5200 lb capacity is what they're rated for, apparently nothing lighter duty is available in a square tube.
Once all that was put together, offroad warehouse had bushed steel tubing with nuts/bolts/washers already setup for $20 apiece and I used those for the trailing arms. I did drill each steel tube and thread in a zerk fitting to make the bushings last longer.
Once that was done, I trued up the solid axle, tacked the arms in place, welded them top bottom and sides, then took a sawzall to the center section of the axle and presto! independent arms.
This pic is right after I flipped the frame over. Doing that in limited space by yourself with heavy BFG's already mounted on arms flopping back and forth is a bit of a thrill.
D727411_057109_963689
airbags
An ebay seller had 2600lb capacity airbags on sale so I bought a couple. They have about 6 or 7 inches of travel from flat to full extension. They have a single bolt hole in the bottom plate and dual holes in the top plate. I welded in crossbraces on the trailing arms then cut a crosspiece to mount the bags to at the top of the frame. A little persuading with a pipe wrench to get a neutral angle and then stitched them up all the way around.
The lower mount for the bags is a piece of allthread welded into a 1/4" steel plate, while above I drilled 4 holes through the top of the crosspiece to be able to access the bolt heads should a bag fail or otherwise need to be replaced.
D727411_057109_964884
D727411_057109_964882
bumpstops and shocks
of course, it wouldn't be a baja trip if something didn't go wrong, and in case of catastrophic airbag failure I decided to mount some solid block urethane bumpstops at two points on each trailing arms. Also, when the air is out of the bags for storing the trailer, the bumpstops will carry the pressure of the weight of the trailer.
D727411_057109_964896
D727411_057109_964982
Also, Edelbrock is blowing out their shocks. Gas charged, inertia active, good quality, were $60-70 dollars apiece on a discounted, buy 3 get one free sale for 4 for 44 bucks! The ones I got were supposed to be for a lowered dodge durango but of course you can mount them wherever you want. I set these up so they'd not top out or bottom out across the swing of the trailing arm.
D727411_057109_964898
D727411_057109_964890
They actually work pretty well, even at that angle. When I disconnect the hose form the bags, allowing them to collapse completely, the shock instantly engages and maintains most of the frame height. Whereas when you slowly deflate the bag, the shock "allows" the frame to gently fall. It'll be interesting to see how they act offroad.
wheelwells
Next up were wheel covers. Since a lot of camping is about "thing management" as a good friend of mine says, you can't have enough flat surfaces on a camping trailer. Also, I wanted something flat-topped and sturdy to be able to be stood upon. I used .190 thickness aluminum diamond plate, cut 6 individual pieces for each wheelwell/fender/deck and tigged them all together. Then to maintain the airtight-ness of the frame, I tigwelded short bolts on the top of the frame, drilled holes in the aluminum to accept the bolts and cranked it all down with acorn nuts and lockwashers. I can stand on the wheelwells just as they are, with no steel backing, and they don't budge.
D727411_057109_963649
D727411_057109_963641
D727411_057109_963643
D727411_057109_963755
There's aluminum decking in there too, but that is for another post.
Great build...love the "lines" of it :beer: Welcome to Mud :flipoff2:
I'm curious why the independent over traditional suspension....better reliability and ride? I really find the mechanics behind it intriguing. Might not be a bad idea to carry an extra bag. The frame looks first rate.
As far as your measurements for the tent clearences..they don't really mesh, but speaking first hand of having two trailers that both flipped over the back, and both had changing rooms(or annexes') you won't regret it. It's very handy to load and/or unload if it's raining. I bring along a folding aluminum sawhorse to setup the tent, it then does double duty as a chair or table. I keep the portpotti in there for the :princess:
Sounds like you put some thought into how this is going to work. Looking forward to more progress..good luck:clap:
Pat
Great build...love the "lines" of it :beer: Welcome to Mud ************
Pat
Hi Pat!
Thanks for the comments. i'm sure you won't be surprised to hear from yet another person that your build was one of the ones that was most inspiring. :)
I have a friend who is an absolute wizard at metal fab, and after driving in his homebuilt 4-link long travel Lexus powered Ford Ranger at 70 mph over the biggest whoops in Glamis and feeling like I would've been comfortable sipping a coffee at that speed, it was that smooth...that kind of got me headed down the independent suspension route. That, plus the fact that I've been with Jman on numerous Baja trips when we've had breakage of one kind or another made me decide on independent.
To be fair, Jman does absolutely use his stuff. Friendly warning to everyone....don't ever buy ANYTHING used from that guy...truck, trailer, cattledog...it's been beaten to within an inch of it's life! :D
Having said that, I do plan on carrying an extra airbag though. :) And the way I'm building this, you'll be able to change out a bag mostly from the inside without disassembling the trailer.
The RTT does have the annex, but I was planning on coming off the side though there will be a side door to the trailer. Which reminds me...need to check annex height to be sure it'l reach the ground when hung from the tent, and I may need to cut a flap and stitch in a velcro closure on the back wall (against the trailer) to access the side door. Thanks for reminding me. :)
Nice, and nicely done.
About the landing gear wheel... that was what I originally had on my jeep trailer upgrade. It collapsed in the first attempt to move the trailer. The thin sheetmetal rim will not take any kind of side load, despite its weight rating. I had to go with a better rim/tire.
https://forum.ih8mud.com/trailer-tech/497471-jeep-trailer-wheeled-landing-gear-experiment.html
thank you for that tip. I'll be on the lookout for that, though so far it seems to be pretty sturdy...granted i haven't REALLY loaded it up yet...
coupler and air system...
For a coupler, I was looking at the locknroll and the maxcoupler...I even thought about fabbing my own using some oversize heim joints...But after pricing what quality heims of that size cost plus factoring in time vs. the quality of professional made, I decided on the maxcoupler.
D727411_057109_963799
Here's a shot of the total travel available with the airbags and bumpstops...one bag inflated, one deflated:
D727411_057109_964984
And here's a shot of the pivots and arms while I was setting up the shock mounts:
D727411_057109_964072
I spent a few hours yesterday with 2 welders and a bottle of soap solution, tracking down every pinhole leak in the frame. I thought I had them all nailed down but last night before going to bed I pumped it up to 80PSI and found 2 more tiny ones. Luckily they are in easily accessible areas so I'll have those fixed this morning. I'm using two quick-disconnects to on and offload air from the frame, pics of that in a bit...
Thanks, Drew. BTW, I read all 50 (!!!) pages of your thread. Unbelievable and inspirational. :)
I'd love to see your camp rig in real life...what's your next planned excursion? I'm trying to get mine finished in time for a firearms training trip to the nevada desert at the end of october. I don't think I'll have any problem (knock on wood) with that deadline but i do know that everything takes 3 times as long as you think it will...still, gonna try.
So here's what I'm trying to do...For this rig, I want to be able to carry 15-20 gallons of water and an equivalent amount of gasoline. Two problems: weight and bulk. I've used jerry cans or other 5-gallon plastic cans before and those are all very well and good but they are heavy to store or to carry, if they are anywhere up on a storage rack your rig becomes topheavy, you have to worry about miscreants stealing them and they take up a lot of space.
The idea I'm working on came to me while I was initially designing the frame of this trailer. I calculated out the volume of the negative space between the trailer frame members...by that I mean the air space, not the volume inside the trailer frame itself. Here's a picture to make it more concise:
D727411_057109_964199
as you can see, two tanks suspended within the confines of the frame will carry a total of over 20 gallons of gasoline. A tank built to ride over the frame members and at 1.5 inches tall internally will carry almost 20 gallons of water.
Here's what I designed. All the tubes are for filling the tanks above and below the trailer deck, pressurizing the tanks (now you know why I want compressed air storage) and for retrieving liquid from the tanks:
D727411_6857112_600517
and
D727411_6857112_600502
I think that this way, if the tanks are built with internal baffles and constructed properly, carrying capacity objectives can be reached in that about 20 gallons of both fuel and water can be stored, the weight will be as low to the ground as is possible while maintaining ground clearance, no bulky tanks will be required and no pump needed to void the storage tanks.
The downside is that I'm looking at running a total of 85 feet of tigwelded aluminum bead! But I did find a guy online with an aluminum spool gun so maybe I'll hire him to stitch everything up after I've tacked it.
unless someone on this board has a mobile setup and the know-how to use it and wants to make some side $$$?
couple shots of the air quick disconnects:
D727411_057109_975731
D727411_057109_975739
I'm using a sheet of aluminum for the deck. .190 thickness, 5052 alloy...Tough, doesn't corrode, lightweight, doesn't need finishing, and SHINY!
D727411_057109_975866
D727411_057109_975952
Drilled holes are to access airbag bolts and to fill as-yet-to-be mounted fuel tanks.
D727411_057109_975854
I'll be spending lots of time with the drill and the tig today, boring holes to mount the deck to the frame and then welding studs onto the frame. The plan is to sandwich the deck between the frame and the steel cage for the trailer box itself.
