- Thread starter
- #41
Time for an update, lots of changes...
first, got the trailer registered. DMV was the DMV as usual and to keep things simple i stripped everything off the trailer and just rolled it in as the frame with wheels. Here it is, parked.
Then my new welder arrived, with spool gun, so I could do the 70 or so feet of aluminum welding I needed for the fuel and water tanks.
I put it all together and it's really nice. Started laying down beads like these:
I used my lift to pick the cage up off the trailer so I could work on the deck and the tanks. that thing is a godsend.
I spent the next few days getting everything together, all the fill, pressure and outlet tubes in placed and air-pressure-tight, going over every seam with a spray bottle of soapwater, tracking down pinhole leaks. It was time consuming to say the least. Now here is my screw up. I was so focused on whether I could do it, that I didn't even think if I should.
Because I shouldn't have.
Once it was all together, the damn thing weighed about 250 lbs. Boy, when I mess up, I go big for sure. Literally 5 minutes after I finished it, I pulled out my plasma cutter and cut it all up again and went a different route. If I'd thought about that issue beforehand, I would have saved about 8 days of work all told, plenty of money, a ton of effort and aggravation, and wouldn't have needed the spoolgun.
On the plus side, I love my new welder, I am using much of the reclaimed aluminum and I learned another aspect of planning. Weight. To that end, I redesigned my trailing arms and updated my sketchup plans to reflect the better design of both the arms and the trailer frame itself. I even got one of the tailing arms redone and it turned out well. I also relocated the airbag to reduce deflection under load and I think it'll be a much better solution.
Before I get to that though, I decided to go with a baltic birch 1/2inch deck. That's already cut and holes bored and in place. SOOOO much lighter...
also I ordered a 20 gallon fuel and 30 gallon water tank and the fuel tank arrived and is mostly in place. Note the reclaimed aluminum...
Now on to the new trailing arms, or rather, the mishap that befell me...
Without too much explanation, I discovered that the skin of the shin is very thin...and pretty much bereft of nerve endings...I didn't realize I'd cut myself until my leg felt like it'd been in a rainstorm.
In my usual style, I was on a roll working and didn't want to quit so I washed it out and taped a pad over it and it seemed to stop bleeding...
See?
until it started again...must've been all the gymnastics with the welder...but soon I was leaving bloody footprints so I knocked off for the day and took care of it.
haha.
So that's it for now. More pics as I take them. Thanks for all the PM support and comments guys!
Sam
See?
haha.
Sam
