Holding the front up with the Bulldog jack gave me an idea...
I am going to make a short, 6in or so, sleeve that will fit inside the main draw-bar location and be able to be pinned with a hitch pin, but it will also have a round mount welded to the front edge of the sleeve. Then I can remove the sliding draw-bar and stuff the sleeve in and prop the trailer up with it, essentially shortening the trailer by nearly 3 feet for storage... we'll see!![]()
Worked like a charm! I made the sleeve out of the draw arm material (2.5x2.5x.25"). I inserted the tube about 2" into the sleeve, then I put a bead on the inside and layed it up thick on the outside to fill all the holes in.
I think it came out nice and it works great! As a side benifit, with a reciever lock, I have now essentially created my first anti theft device for this thing!![]()
I have bulldog jacks on the rear right and left side of my AT bumper...coupled with the tongue jack I can easily and quickly find level on most terrain. You might consider welding a mount for these on your bumper.
Drew, check into the jacks they use on a lot of pop-ups and light trailers. They spring up/flip down and with the proper mount will tuck up under the frame, or close. They are adjustable and nothing is more stable than a tripod
That is my intention, anyway....for the moment.
Ed![]()
I have an idea for the rear to custom fab a few "legs" that drop down like a pick-up slide in camper. But I am so impressed with this Bulldog jack that I may need to scrape a few more pennies together to see if I can mount two out back.
Where do you keep all of them when you are out and about?
Rezarf <><
http://www.pplmotorhomes.com/parts/rv-jacks/light-trailer-jacks.htm
Take a look at these. This idea may be a little far fetched, but with your fab skills seems doable enough. Take the cheap 20" arm off and fab up a piece of tubing with a slot cut into it to accept the stabilizing arm of the jack. Drill a hole in the end of the tube for a pin and you could have an extentable jack for about 30"
The 30" Jacks on this page may be your best bet.
http://norcoind.com/bal/products/consumer/leveling_products/levelingscissorsjack.shtml
those jacks are all pretty good but IMOP they add weight that can be better used elswhere. i know its not that much weight, but i built my trailer light and want to keep it that way. i am soon adding a RTT and a rack to hold it so i wanted support legs also,, this is what i did.
i welded square tube on the rear corners vertically, then made up a "slider" tube to fit in them with feet on the bottom,, i nose down the trailer a bit slide down the legs and then bring the trailer up to level, its simple light and works. i only use one hole for a fixed position and shim to level if needed, but a few holes for different heights is easy enough.
my original idea was to have the legs hinged and fold under the trailer when stowed.
Drew,
Here's the leg on my trailer. Not sure if it can be purchased in the states but it can extend well over 20". The leg is stored horizontally as you see (sorry about the back ground wood pile). To swing down, pull it out and swing downward until it locks. Then squeeze a spring loaded latch to drop the leg down to the ground. To extend it further, release the lynch pin and extend the lowest part as needed and then reinstall the lynch pin.
