6 months ago I bought a rusty 96 with small issues and rust for cheap. Had a very slight misfire. I had the codes ran, and they were for: O2 sensors, multiple cylinder misfire, and specific codes for each cylinder misfire.
The intake tube was duct taped so I put a new tube on. Then put in new plugs (properly gapped), wires, cap and rotor. Still had the misfire but it was pretty minor and only occasionally would it sputter at idle. Fine under load.
Cleaned battery connections, checked most of the grounds but still need to look at a few admittedly. And look at the fusible links (I actually don't know wtf these are or how many there are.)
Over winter the idle got really bad, it would surge up and down from 400 to 800 and it recently lost power and ran really rough and crazy, sometimes dropping to 400 rpm, sometimes dying at the very rough idle. This was right after I got new brake lines, master cyl, and proportioning valve.
Today I opened up the harness that was resting on the EGR pipe and saw that somebody had already repaired it, but some of the repaired sections were burnt so I replaced them. The previous replacement wires were 16 gauge, while the oem wires appear to be 14 mostly. I unfortunately had bought 16g because walmart didn't have 14g, but I figured new wires of the same size would be better than burnt ones, and the difference isn't -that- large.
I've been asking and can confirm (for people's future searches) that the 96 wire harness uses mostly 14 gauge wires , at least by the EGR pipe. The job is quite easy, just a backbreaker leaning on and over the engine standing on the frame. I also pulled the harness down underneath the EGR junk and over the manifold toward the passenger side, far away from that pipe. Fastened in place.
Anyway it runs much, much better now and actually idles at 600-650 (not completely consistent still). Has lots more power and I'm pretty happy. I also haven't had a trans slip yet (probably just jinxed myself) and may be the cause of the 'solenoid' issue. I hope.
Still a slight stumble intermittently so I waited for the CEL to come back on and had the codes read.
Multiple Cylinder Misfire
Cyl 1 Misfire
Cyl 2 Misfire
Cyl 4 Misfire
Cyl 5 Misfire
Cyl 6 Misfire
I've read that I have to check the harness section in the glove box area, but I don't exactly know what I'm looking for there as I can't imagine what kind of damage could be done away from the engine and probably not rubbing anything.
I was worried about the head gasket, but the oil is still at full and clean from a couple months ago. I DO have my oil idiot light coming on/off in the dash constantly. That wouldn't make it run weird, would it? I doubt it.
There is old oil and crud around the valve cover gasket, and the rearmost bolt for the valve cover is busted off (MOTHERF PREVIOUS OWNER!). It could be sucking in air at the gasket, but I have a feeling that's not it. Yeah one bolt is broke but it's not going to make it that loose. And the problem is intermittent. Sometimes it runs A+. I've had a truck's valve cover gasket fail before and have vacuum issues slowly mess up the idle, then it got worse before it finally died on the road, never to start again until refreshing the top end.
I plan to do the same here just because it needs to be done, and I'm also going to remove the EGR system and as much smog crap as possible, replacing all vacuum lines and gaskets, etc but I don't think any of that's the issue. I'm also going to do the head gasket while I'm down there anyway.
I've pretty much ruled out sensors at this point. They'd be fine or bad, not intermittent for half a year. Plus no CEL for them. Wouldn't hurt to clean the MAF or whatever it's called.
Injectors? I know they clog eventually in diesels but is it really that common w gasoline? So again, I doubt it.
Maybe the head gasket is only slightly bad. Not enough to noticeably burn oil or mix oil with coolant? I'll do a compression check when I finally get around to it, but again, I doubt it. Even the coolant temp is always perfect and never gets hot.
What's left?
Edit to add: The fuel filler neck leaks a little when I put gas in. Perhaps air could get in through that, but I don't see how that would mess up the fuel/air mixture, being upstream of the gas on top of the pump.The vehicle is old and rusty enough that it could use new fuel lines, pump and all tubes. I can't do all of this at once so I need to narrow it down and come up with a plan.
Cyl 1 Misfire
Cyl 2 Misfire
Cyl 4 Misfire
Cyl 5 Misfire
Cyl 6 Misfire
What's left?
