I think I can put a keg on 4+ Rear Bumper, and run the tap though the cooler![]()
Does that qualify as an "open container in the vehicle" HHMMM..........
My point about sliding drawers, especially those on ball bearings sliders should be repeated here for those who were not at SNT. Let me preface this by saying that my locksmith truck (Ford E350 Diesel) is built with 5 large rear sliding drawers on super heavy (300 lb capacity) duty ball bearing drawer slides. When parked with the nose of the truck going uphill the drawers really want to slide out quickly when you open them and they are hard to push back in. On level ground they are great. Granted I am not gong to load up my FJ with 200+ LBS of lock hardware, I still I did not want to deal with expense and hassle of drawer slides.
I have seen some builds with wood on wood or wood on nylon slides which would not be so bad, but then again, It is an added expense too.
Mark
If two drawers had identical weights in them and the angle of the vehicle was the same wouldn't the one with the higher friction slides (ie; the one without ball bearings) be harder to push back in?
Yes, the BB slides do roll out quickly when on a uphill slope but mine has a lockout feature so if on a downhill slope they can lock in the out position so they don't keep wanting to slide shut when you don't want them to.
I think the advantages outweigh the disadvantages after having used both styles.
....60 series cruisers, my first love....Are you getting lockers with the new ring and pinions you getting installed?
