So I'm having this problem where my 1985 FJ60 (CA smog legal) has a hesitation or miss as I'm driving from about 2000 to 3000 rpm. It is apparent if I am driving at a constant RPM or if I am slowly accelerating. It's not as apparent (or non existent if I am quick accelerating). I can make it stop hesitating if I disconnect the vacuum line to the EGR and plug it.
I recently purchase and installed a new OEM EGR modulator (thanks CDan!), but I still have the problem. I spliced a vacuum gauge into the vacuum line between the modulator and the EGR valve. At non-idle RPM I see vacuum that increases with RPM, and at constant RPM the vacuum needle is steady, even when I'm experiencing the hesitation. This leads me to believe that the EGR valve is getting a steady signal from the modulator.
So what's the next step? should I replace the EGR valve, look at a carb rebuild, or try something else?
Other things I should confess:
I do have an exhaust leak when the engine is cold. However, I don't think it is an intake leak, at least I haven't detected one using carb cleaner.
The engine seems to run fine at constant speed on the freeway. This problem is really only apparent when I'm driving around town on surface streets.
Thanks in advance for the help.
