Builds My Bad 91 Runner on 39.5's (should have got 42's) (4 Viewers)
I have ordered my first ARB yesterday. For my 40... And will probably receive it a few days before the car;)
ETA on the car is july 10... Dont want to drive 2500km to get it home... :cheers:
Had some trouble with my car lately, first my starter had to be replaced, then the batteries and 2 night ago a braketube failed. So I had to cut, make a new peace and mount it together.
Today I take my runner to Lapland Trophy in the north of Finland. This is a 24hrs GPS trophy competition and Im looking forward to it.
Will post pix afterwards, I reckon monday-ish... :)
Well, I had lots a fun this weekend. But there weren't much wheeling... I had only driven 150km (of the 600km) on my way to Raajarvi just outside Rovaniemi Finland before my rear diff broke down. It was one of the bolts holding the carrier bearings that had unscrewed itself. Had an extra diff with me and after being towed to a nearby garage I changed it. A break line broke down to, so I had to get a rally-driver living nearby to make me a new one.
Well, got going again... The next day we checked the gears on the broken down diff, the damage was acceptable so we got a finnish mechanic to set it up and that was impressive. We changed back again and the car was ready for the competition saturday morning.
On the first check post I ran over a three trunk and blew a tire! So I had to change it. I ran one more post with 4wd before I blew the CV joint rescuing a Jeep (with a hot blond Swedish girl in) out of a mud/water pond.
We took the left front side apart, checked for damaged and found that the joint was ok and put everything back together. tested it and after rolling the car forward 1 m the cv popped out again. We took it out once again and welded on a few rods to prevent it from popping out. But something else has twisted so when it turned it wanted to pop out again.
We went to eat and took a time out. After a while we decided to run enough posts to get a result. And we minimum had to get 10 approved posts. So we ran 17 post with only rear wheel drive. After about 10 point with 2H we rearranged the vacuum system for the ADD so that it disconnected when put in 4wd so that we could save the clutch and also get better control.
So now I have started collecting parts to do a LJ70 front axle swap for my car! Also some arbs are on my to-do list...
The garage that set up my rear diff took the cost with new gears and are installing it as soon as it gets here...
I`m still a bit tired though...
some pix are posted here... http://pirate4x4.no/forum/showthread.php?t=4630
Knix
He he, it was a reference to my technical breakdown on the way to finland, and the time it took to fix it and the time I got there... It took allot more time than anticipated... :)
But it was worth it!
Check these pix out!!! http://pirate4x4.no/forum/showthread.php?t=4630
Offroading extravaganza... ;p Its from my last trip to finland, more photos added. Follow the links in this to, then you can see the amazing terrain.
(Sorry for not posting them here too, but there was just to many pix and the resizing is soooo boring...) :cool:
Just joined this forum, and I just gotta say that that's one sweet rig you got there! Especially considering the hoops you gotta jump through with your DMV and such! :cheers:
Living here in Arizona, I just cringe at the site of dunking a rig in mud... I just see that as a 2-3 days of clean up! :D Anywho, keep the updates coming!
Later,
Chad
My project build on WAZ... needs to be updated, but I'm too busy working on other junk...
http://wheelingarizona.com/forums/viewtopic.php?t=9078
Got some parts today... ;)
I usually sleep lying down... :cheers:
I`m starting the cutting on Monday or Tuesday I think, it will be great.
I have ordered new 4-link arms from all-pro also, with jonny joints. But I am still concerned about the front/rear ride hight.
Will post pix along the way! :D
Your gonna cause me to totaly F' up my 4Runner! :D
and spend a small.........er..LARGE fortune
:flipoff2: keep us posted
hmmm, wanted: another Toyota 4runner, must be 5speed, 4wd,
oh sorry thinking of placing another add :doh:
There went my budget for a 60
He he, nice to be helpfull that way!!! With just a few thousand dollars youll end up with a good car... :cheers:
Starting slowly today, will keep you posted... ;)
