My 78 FJ40 Project - HD
you must have a lot of time and money at your hands , that's a big job. good luck
Nope, not much of either, that's why it's taking so long. :) The guys in the clubhouse warned me. Haha. I think I got my second wind and bit more time in the next couple weeks. So I hope to make some progress.
Look like you are doing it right! Thanks for the thread Jack.
Time to get back to work!!! Moved to Tennessee. Great club support here.
Put the 40 back together for the move so I started to take it back apart yesterday. I also roughed in the barn doors. Garage is smaller than I had in WI but I'll have to make do and wife's car will have to sit outside. :)
I took the tub off and started work on the bottom. I scraped the years of crud off, cleaned up some of the POs welds, added a few more, some reinforcement, scuffed, primed, seam sealed and covered with a home-made lizard skin alternative. Basically I added glass micro spheres used in aero space to some Rustoleum.
Worked on the exhaust today. Got it tacked in.
When I ordered some steering parts from Summit, I found a muffler and exhaust pipe they had on clearance for cheap. The picture on summit made it look like it had smooth bends instead of the actual crimps, but I made it work. I took the clamp and drilled out the bracket so that I could mount it higher up through the rubber directly. I bent the bash plate underneath and might need to modify it a little, but I got the exhaust through it rather than under like was stock.
Spent a lot of time stripping the tub. Chemical stripper, wire brushes, stripper wheels, My trusty drill even finally gave up and died. I made some reinforcement patches for the under-seat toolbox, sanded the entire tub, treated for rust, and sealed it. Really happy how it turned out. Can't wait to get the body work done and get it painted!
Making some great progress! I wont win any awards for my paint job but after a couple of weeks with long hours prepping, sanding and more sanding, I finally got some paint on the tub. Very happy to see it coming together!
On Craigslist I found a ShelterLogic garage. They sell them at Tractor Supply. Worked really well. I had considered using a fan to blow air in after it went through a furnace filter, but there was a little breeze and it wasn't a super tight seal, so it wasn't really needed yet kept most debris out of the paint. Around 10MPH wind though the tent wants to take off if you have it on pavement and not staked in the ground.
I found a local auto paint supply store and described my project. They set me up with UPOL primer. Worked good as far as I know. It was a little rough and required a lot of sanding, not sure if that was my setup though.
I purchased a $70 spray guns from Home Depot, came with two guns, regulators, funnels, brushes, etc. Primer specs suggested a 2.2 tip, stuff was thick, so I ended up buying a second old-style gun from Advance Auto and used it for primer. The other two I used for base and clear.
I had what seemed to be the usual trouble getting the right color for 416. The mix turned out very olive color. The tank cover underneath was in great shape and we matched the color from that. I think it turned out a little darker, but the color is very interesting. It looks dark in the garage under flourescent lights but in pictures it looks very light.
The basecoat went on good
It got pretty hazy in the tent for the clear, I could have used lights. I had a couple runs with the clear, but I'll sand and buff them out and retouch if necessary when I paint the remaining pieces. I was very anxious to get the tub done so I could put it back on the frame and continue reinstalling everything over the winter. I missed one weather window and another one popped up later that allowed me to prep the trans tunnel, bib, tank cover, and fenders. Enough to get most of the truck together and wired!
I ended up with BASF paint, LIMCO line. Basecoat Clear. I turned out very shiny, maybe too shiny for a truck. Something to consider when you're painting yours. Outside temp needed to be 60 degrees. I painted outside then after an hour or two moved it into the garage which stays around 60.
Very happy to get the tub back on the frame!
Now I'm working on the wire harness and started a thread here: https://forum.ih8mud.com/threads/wire-harness-refurb-78-fj40.823534/
Awesome work and great thread. I noticed you are running the stock carb and aftermarket headers, me too. Having a tough time finding how to connect line and where from fuel breather off tank as I have no charcoal cannister, ideas?
Thanks! Sometimes I wonder if anyone reads these posts.
At this point I can't say. I haven't done more than just run the motor for a half a minute or so at a time. I need to hook up all my vacuum and emission lines yet.
definitely do read em!
so much to learn from what other people are doing to get around certain problems n such.
in the process of rebuilding my own 73' 40, great fun and a lot of hard work. regularly look at people's build threads to hopefully solve problems before i come across them :P will be keeping mine (almost) stock, i think the hardest part though, as many people will find...picking the colour! :( hah
looks like you're doing a great job though, and having a lot of fun in the process!
look forward to more updates :)
