Builds My $1500 82 fj60
Houston, Texas
I saw this on Craigslist and I couldn’t pass it up. Even though I should have. I’m sick, I’m sure you all understand.
It’s an 82 with a sbc, ranger overdrive, OME(is it though?) suspension. Running and driving. And lots of rust.
Drove it around a bit, took it to hidden falls and the transfer case keeps disengaging the front wheels while in 4wd.
First pic is the day I bought it. After the hidden falls trip i dug right in to the rust repair.
Rebuilding the windshield frame was quite the project. Would not recommend doing it. I got some seats from a junkyard Mercedes ml350. The original ones were pretty rusty.
WOW!!! You are a trooper for taking that on!! Nice fab work so far!
For the t-case kicking out in 4wd, make sure there is nothing blocking the shift lever underneath so it is not fully engaging.
I ended up rebuilding the t-case. It needed it. Was toast from too long drive shaft. Will explain in following posts.
Woah dude. My rust repair I’ve been dreading suddenly looks like nothing.
New headliner, new carpet($30 worth of Walmart area rugs) and a shift knob for the ranger overdrive that I designed a d 3d printed to match the t case style
35’s and beginning of rear bumper fab. Using the rest of the 55 junk front bumper and a custom made tire swing out, also made from pieces of the ridiculous front bumper that was on the junk 55. The swingout kit (bearings and housing) I got from amazon.
