Must have CHEAP mods to 100 Series
LOL here is one reason because mine has twin-cylinders and yours only has one so in any conditions mine will fill the tire twice as fast as yours. Up at high elevation it makes an even bigger difference LOL Yes I did spend my own money on it LOL. Also...LOL...it has auto-shut off so you can just hook it up and forget until you hear it shut off then move to the next tire etc etc LOL just makes it easy LOL
I am little disturbed and concerned by the maniacal laughter.
Right...
Ok new one - Lasfit brand LED lights to replace original bulb types for front/rear turn signals, brake lights, and reverse. Have the option to include built in resistors so you don't have to splice in a separate resistor to prevent hyperflash. Just plug and play.
What size lights did you get? Ie h4 h4 etc.
I'm suprised no mention of the spare tire lift or the diode alternator mods for a few bucks each:
Some other cheap favorites of mine, some mentioned before:
  • - Homemade roof shower
  • - 8020 extrusions to replace roof rack bars
  • - @LandCruiserPhil mud flap eliminators
  • - @suprarx7nut YotaMD fob
  • - JDM rear wiper blade arm
  • - @TRAIL TAILOR recovery points and antenna mount
  • - @cruisergear AC drain relocation
  • - LED dash, door card, license plate, reverse, overhead, etc. bulbs
  • - Clear corners can be had for under $100 on eBay (quality is so-so)
  • - Custom speaker grille fabric
  • - @BenCC M2V2 RAM ball dash mount, center console organizer
  • - Pin 17 mod for fogs + high beams
  • - Jumping the accessory relay for constant 12V power to outlets (rather than switched with ignition)
  • - Doorman windshield washer nozzles
for everyone doing LED blinkers this 8 pin relay works perfectly on my 2001 LC. Check yours to make sure it's 8 pin. it can be find on the frame of the brake pedal. if you follow it up it is screwed into the metal framing.
would my 98 be 8 pin? do I need just one relay or 2 ? thanks. I would love to upgrade my blinkers to be brighter.
My favorites are:
- Cup holders from @BenCC
- LED lights (inside and out)
- Backup cam
- Well window visors
- Plano 108-quart storage trunk
This may be a dumb question, but when I upgrade my interior lights (dome, flood, etc), do I need to get canbus LEDs?
Smart Tap LED flasher. I have this installed and it offers departure and arrival function with your turn signals. Fun way to update the appearance of our old cruisers. Also allows you to run LEDs without hyper flash. Simple plug and play.
I picked up some Velcro adhesive patches and an expedition pouch. Has been there about two years now and no issues with the Velcro adhesive coming unglued. I like it because I can keep leather man or other odds/ends and when switching vehicles, just grab the pouch and go. No real impact to arm rest either
What is the departure and arrival function?
