Ahhh. I did not know that it was part of the ECU on the 570 instead of a separate module as I had been reading about with the GX platform. So an ECU from a GX 460 would be what you would need?On the GX it’s a separate module. On the LX it’s actually part of the skid control ECU. You would need to replace that, but also rewire quite a bit as the pin outs change.
Im always on the lookout for a used ECU but no dice so far.
Good point. Could confuse everything, even if one were to get it wired in. Just wondering. I have a 2004 GX 470 230K, and am looking for a bigger version like LC /LX. Since 06-07 LX 470's are close to what an early model 570 are in $$ I was leaning toward the 570 with more HP-Torq and crawl control. After driving a LR LR4 I must state that I like the fold flat seating and their Terrain Management System is very good but obviously reliability and cost of repairs is a deciding factor. I know Lexus / Toyota is Wayyyyy better built but thought if one could put a Terrain management system in a 570...wow! best of all worlds. At least for me.Honestly not sure that would work. Certainly not plug and play. Question would be whether the terrain select functions on the GX would mesh with the skid control on the LX.
I don’t understand why you think terrain management is necessary to update in a gen 1 200. What specific function is necessary?Good point. Could confuse everything, even if one were to get it wired in. Just wondering. I have a 2004 GX 470 230K, and am looking for a bigger version like LC /LX. Since 06-07 LX 470's are close to what an early model 570 are in $$ I was leaning toward the 570 with more HP-Torq and crawl control. After driving a LR LR4 I must state that I like the fold flat seating and their Terrain Management System is very good but obviously reliability and cost of repairs is a deciding factor. I know Lexus / Toyota is Wayyyyy better built but thought if one could put a Terrain management system in a 570...wow! best of all worlds. At least for me.
I am just basing it on my experience with 2004 GX 470 ATRAC system. Have not driven a 200 series LX 570 offroad at all. Just thinking of getting one and was wondering if a more advanced computer monitoring / management of slippage and braking along with application of torque to specific wheels during certain situations and conditions would be improved with a Terrain Select Module.I don’t understand why you think terrain management is necessary to update in a gen 1 200. What specific function is necessary?
Awesome, thank you for the input. That is good to know. Like I mentioned I have no actual experience in the 200 series so I appreciate the information. I am going to remove the 3rd row permanently and then figure out what to do about those pesky running boards. I guess SLEE is not making the sliders for them anymore....bummer.I run pretty regularly with my local GXOR chapter - I don't think you'll be disappointed in the leap from ATRAC in a 470 to a 200 series with crawl control.
Sounds like the crawl control is all I need then. Fantastic. Searching for the right 570 everywhere...No difference with 2008 to 2013 right? Want the earlier body style with the more conservative grill work..easier to trim up if needed I think as well.CRAWL is what you need. Don’t worry about MTS. When i off-roaded last year at Big Bend, i used CRAWL exclusively. I did try MTS but I did not find much use for it. CRAWL is awesome IMHO...it is so good (but very noisy!!) that i feel guilty at times in using it...because it makes everything so damn easy!
So you were driving with crawl control on all the time?
No!! Just when i need it. I was in 4-LO most of the time...and just turned on CRAWL as needed.
Unless something changed on 16+ MY, you were using MTS since it gets activated when you engage 4-LO.
