Have 165K on my 2000 LC and mileage has been going down for a while.
Pulled all my fuel injectors and took them to a fuel injector service guy.
They were checked for leakage, spray pattern, volume of fuel at cruise speed and idle. Ultrasonically cleaned and retested. Mine were somewhat clogged and spray patterns were poor. The idle fuel volume changed the most and they were more even across the set. They are marked so the leanest ones can go into front of engine where cooling is better.
My Scangauge shows a couple of MPG better around town, but that is not a good test. Heading out to CruiseMoab and will get some long trip results then. Expect the ECU will be re-calibrating for a while, so that will also be a factor. If it turns out with a decent improvement it will be worth the $200 to have them cleaned and tested.
If your injectors are in good shape this is not going to help you.
