I have the bucket seats and brackets from a '75 that I'm going to mount in my '70. the back brackets do not line up with any of the threaded holes, how'd you(those of you who have done this conversion) mount the back brackets, since that is above the part of the tub in which you cant access from underneath? If need be i will drill the holes and then cut out the metal weld a nut in place and then weld the metal back but i wanted to see if anyone did someonething different before i go cutting away at the tub.
Also, the tall back brackets go with the passenger's side seat correct?
Jim
Jim
