- Thread starter
- #141
The brake banjo bolts that connect the brake line to the caliper bypassing the need for a small hardline at the knuckle.
That's a totally unnecessary item.
Either get some made, or just use some rubber brake lines that have the same fittings but are a litttle longer than stock. I ran my 40 just using a longer rubber line for years.
You live in LA so there will be a shop (probably dozens of shops) that can make up appropriate lines. Check this for an idea:
I buy the -3 ends, -3 adapters, and the -3 bulk hose from Orme Bros and make my own brake hoses. Not that hard (once you figure how to not poke the ends of the SS braid into your fingers!) and then I can make them 'on the truck.'
I also order one extra of each part number, a couple extra ferrules, and enough extra hose to make the longest hose on the truck. That way I can make field repairs if necessary and it all fits in a ziplock sandwich bag.
What have people done about extending their sway bar mounts? Is there a kit available or is it mostly custom since all SOA are different? I don’t want to ditch my sway bars as I like to drive my rig around and also I drive long distances to the trails.
Been a while since I checked this thread....
Check with orangefj45. He was working on custom kits a while back.
Butt
