After reading the woes of the studs shearing.loosening off, I checked mine as I did have some grease on the bottom half of the knuckle and suspension arm.
I found one of the front studs sheared off, but was still in the arm, a little pull and it fell out leaving the rest of the stud up in the knuckle, the other front stud was loose, I tried to tighten it up, but it feels like it is pulling out the thread in the knuckle, so stopped doing it up, the two back studs are tight.
As only two have come adrift, would you think that the seal will be ok? and do you think I could get this done without a strip down?
Is it possible to remove the arm that bolts to the knuckle without to much trouble?
Any help on this would be greatly apprieciated, I have only had it a week!
Kind regards Mick from London UK
