Hello all, in the middle of a front disc conversion on a 1967 40. New mini truck master & booster, all new brake lines, etc. My question is, the pedal doesn't get hard. Rear brakes are adjusted, bench bled the mc twice, bled the whole system 3 times, checked booster to mc pushrod length, checked pedal to booster pushrod. No air has come out while bleeding recently, all clean new fluid all the way to the rears. Pedal still only gets hard at about the last 1" with engine off. Pedal stays hard while held down, so no leaks. Which port on the master is for disc and which is for drum? Maybe I got the wrong axle in the wrong port? I'm assuming front port is disc and rear is for drum? This is the only thing I can think of other than a bad mc? Any other ideas?
