- Year
- 1997
- Vehicle Model
- 80 Series
- Mileage
- 257000
- Color
- Gray
Been going back and forth on this but she needs to go:
1997 257k Miles NOT TRIPLE LOCKED $14,000
Everything works as it should, she runs strong, drives straight and shockingly no underbody rust issues for a midwest truck. I've had her for three years and have dumped a ridiculous amount of money into her, got a pretty thick folder of receipts and invoices to prove it. She's not dolled up at all she definitely would clean up a lot better but I got some basic pics and I made a list of work done. I added a lot of small things but I wanted to be thorough, believe me I could have added a hundred more small things if I really wanted to. Here it is:
Completely baselined 2 years ago when I bought her, all fluids changed, greased, lubed and all that good stuff religiously. I keep an excel sheet for it, have been using Shell Synthetic and I undercoated her before each winter….used clear film not black to hide things.
10/24 Just had all fluids checked, changed, flushed, everything greased, tires rotated and new Toyota plugs. Got a clean bill of health with a full inspection.
ARB Front
NWTI Rear
XO Fab Sliders
Re-upholstered Leather Front and Mid Seats Also Center console pad
Hi Lift Jack Mounted to ARB w/pad
Painted Carpathian Gray 2/22
New Battery 8/22
New Window Runs 9/22
New Powerstop front rotors 7/23
EGR Delete Kit (original parts included)
ABS Delete Kit (original parts included)
New OEM Radiator and Hoses 9/22
New Thermostat 9/22
New Hood insulation 1/22
Door Jam switches replaced 1/22
Cooper Discoverer Including Spare 285/75/16 1/22 @ 238k
New Denso Starter 3/22
Toyota Premium Car Horn (from 200 series)
OEM Clear Corner Lights 3/23
Clear Signal Lights
LED Dual DRL and Signal Lights in ARB
Pioneer Bluetooth head unit with Rear View Camera
New Speakers all around
Keyless Entry Remote Start Alarm
Wired TPMS
ALL Interior lights replaced with LED (dash, controls, domes…everything)
Kut Snake Fender Flares
New Hood Insulation
Teq and 100 series Badging
Third row removed but I have them
Black Dash Trim Kit (only used partially
)Knuckles Rebuilt 12/21
New Tie Rods 12/21
New Advics Brake Master Cylinder 10/21
Traction Boards/Axe/Shovel Mounts
Differential Plug kit 12/21
New Dimmer switch 2/22
New OEM Air Filter
All Belts replaced 5/23 245k
Throttle Body/Manifold Cleaned 5/23 245k
Dobinsons 1.75” Suspension Kit:
C59-210V
C59-221V
GS59-683
GS59-682
SD59-824 (steering damper)
RB59-522K (caster correction bushings)
Known issues:
Common rust in corner of rear hatch window, I had this treated when she was painted but it’s there
Windshield buckeyes
Common crack in dash at center of steering wheel, not a bad one but it’s there
Rear badging is misaligned
Rear bumper needs to be adjusted, low on one side
Steering Wheel has a nice stitched wrap on it, I’ve never removed it I’m assuming it doesn’t look too good under there
14K
ARB Front
NWTI Rear
XO Fab Sliders
New Battery 8/22
New Thermostat 9/22
Clear Signal Lights
Wired TPMS
New Hood Insulation
New Tie Rods 12/21
New OEM Air Filter
C59-210V
C59-221V
GS59-683
GS59-682
Known issues:
Windshield buckeyes
14K
