Is it important to use metric cotter pins?
I just realized the other day that I used bailing wire in my drag link end and forgot to change it. It really doesn't matter as long as the task in accomplished. I'm leaving it there.
Bailing wire is a little soft for the usage in steering components. Maybe you should upgrade to..... a 6 penny nailer?
Rick
bailing wire will hold leaf springs in place to limp off of a trail i think it can keep a nut from turning from vibrations (that is the only reason of the cotter pin anyway. (keep nuts from backing off when having vibrations) so not much load (if any) is excerted on the pin or in some cases bailing wire.
sure... but why are cotter pins so darn hard but bailing wires is soft like butter to cut.
I agree it probably won't go anywhere, but cotter pins are tougher and will last longer. The bailing wire may rust away completely one day and the nut falls off... I would install a cotter pin myself.
Isn't asking about metric cotter pins a little like asking about European vs American Muffler bearings?
Metric cotter pins are real and readily available. I have a bunch of ASE cotter pins and wondering if I should use them. I take it the answer is yes. I also have lots of bailing wire and coat hangers in case I run out.
again a pin is a pin. if it fits in the hole and will do the job properly then it will work.
