This is information based on this installation and is in no way a factory or manufacturer guide to installing bumpers of any kind. If you use any of the ideas presented here, you are doing so at your own risk!
So, the MetalTech bumper order arrived this last Thursday afternoon. I spent most of the morning taking apart the GX470 in preparation for the bumper install. Key things to consider as I was prepping the 470 were the lighting included with bumpers and the existing backup camera from the 470. The existing front bumper removal is very routine and since I was removing one with a hidden winch, I am not going to go into any detail other than a couple pic's.
notice that the horizontal cross member is removed and there is a support extending from the center of the vertical support that has to be cut off as it interferes with the winch.
Speaking of winch's I have a Warn 9.5Ti and it is too tall if mounted to the winch mounting plate as it comes from the factory. Later on that.
The removal of the rear bumper is also very straight forward but be aware of one very important thing. If you have a 2" receiver bolted to the back of your 470, be very careful when removing the bolts. Soak them with lots of BP parts blaster or some other type of bolt lubricant because if you break these bolts off, you are going to either drill and extract, retap or weld.
Here is a picture of the passenger side interior trim pulled away for access to the plastic and rubber grommets you will need access to for the wiring.
After you remove the rear bumper and 2" receiver you will need to remove all of the plastic bumper skin supports and the plastic cover of the interior air vents.
Here is a picture of the bumpers as they arrived on pallets. Very well wrapped and labeled for protection.
To be continued:
To be continued:
