Metal-tech Pegasus Stage-5 and Goblin Stage-3 bumper Install
Can you tell me which factory wires you tapped in to for the rear lighting and backup camera? Are any instructions included with the bumper relating to the wiring?
I did not have any instructions on the bumpers. The wires you tap into are obvious when you pull the rear door panel. Here is a pic.
Here is the back up camera wire
Here is the harness I made
Just make sure you solder all connections. I used the gx plug for the camera and the backup lights came with pig tails. The camera plug is NOT waterproof so you will need to wrap it very well with a high quality electrical tape when you are done. You could also use rubber tape..
I made all connections in the door panel, not in the rear side panel, there really is not enough room in there.
