My 80 got the following attention courtesy a few packages from CDan last week (all OEM unless noted):
- New Air intake hose
- All new (non-formed) vac lines
- New throttle body gasket after remove and cleaning
- New valve cover gasket and new bolt to replace broken one
- New plug sleeves
- New plugs
- New valve cover hoses x2
- New PCV
- New T-stat and gasket
- New plug wires
- New rotor and dist. cap
- New blue fan clutch
- New fuel filter
- New belts
- New oil (mobile 1 5w40 diesel truck), oil filter, and air filter
- New tie rod ends x4
- New tie rod and drag link/relay rod courtesy Christo Slee
- New shims for sun roof to better adjust closed position
- Blue Sea 12 and 6 fuse sub panels (one under PS seat ala christo) and one either in rear cargo area or under hood.
- 12v power points in center console x2 and rear cargo x3
- Interior winch controls courtesy christo
- New hand throttle to replace damaged one (courtesy remote start installers
- Set timing to adjust for all new stuff above (still can't figure this out)
- Adjust throttle cable to get better throttle response from new cable (courtesy CDan)
- New auto tranny shift knob to replace factory one with worn leather
- New steering wheel to replace very worn factory wheel (got the wrong wheel sent from cruiserparts.net after waiting 5-6 months).
