For Sale Meet Clifford, 1988 Toyota Land Cruiser FJ62 - $6,000
Year
1988
  1. 60 Series
This is Clifford. He needs someone to give him the love and attention that we haven't been able to recently.
1988 Land Cruiser, FJ62 with fuel injection and automatic transmission, about 315,000 miles. Recently-installed Auburn limited slip rear differential (less than 2000 miles). Upgraded Euro headlights (high beams and low beams, with upgraded wiring). External transmission cooler with additional electric fan installed about 20k miles ago, makes a huge difference in transmission temperature.
Push-button 4WD works, locking hubs work. Thermostat replaced within the last 20k miles or so, with a very thorough cooling system flush done at the time. No overheating issues. Runs and shifts well, gets 12-13mpg, which is about as good as you can expect on the highway with these (especially at this mileage). Interior is in decent shape but with a few broken plastic pieces in the center console.
Many dents from previous owners and hail over the last couple years, a few rust spots on the body, but pretty much rust-free structurally/underneath. Clear coat issues in the paint. Probably needs new steering tie-rods, probably could use new shocks and springs, has a few leaks, nothing too surprising for this mileage. Just haven't had the time/energy to replace those maintenance items.
Okay, photos incoming, and a short cold start and drive around the block video. I'm not going to take the time to caption all of the photos individually, but happy to describe any that might be confusing or need more clarification (rust vs. dust for example). I think there might be 80+ photos, so it'll take quite a few posts to get them all up here.
No rust to be found on the floor back here.
Looks a little like rust at the seam, but I think it's just gunk/dirt.
Just dirt, I think.
Dirt/grease in the carpet. All tie-down hooks intact.
A few holes in the fender vinyl.
Rear washer reservoir intact, works fine.
Comes with a few tools. No jack, but I believe it has the pieces for the spare tire lift.
Left rear taillight cover broke at some point (cracked from previous owner, eventually fell apart).
This rust spot isn't terribly deep, I don't think.
Tailgate got beat up by previous owners. Opens/close/locks just fine, but obviously it's seen better days. Dent in the bumper.
Liftgate interior in good shape, rear defroster works.
Liftgate has rust spot on lower right.
Liftgate rust spot.
Someone did a touchup here at some point...
Left front door. Surface rust only, still solid.
Left front door.
Left rear door, rear lower corner.
Left rear door, lower front corner. This is the worst rust on the truck.
Rear? wheel well.
Left front door, small rust spot on front lower corner.
Small rust spot on driver's door, lower front corner.
Left front wheel well, front side.
Left front wheel well, rear side.
Just a little surface rust on the frame, nice and solid all around.
left front spring, front side. Obviously needs OME kit. Hasn't been any noticeable issue for going around town.
Front bumper's not bad, but not perfect.
Nice gouge from a previous owner.
Paint peeled here and a few other spots recently thanks to gigantic hail a couple years ago.
Closeup of the paint that peeled on the cowl from a big hail dent.
The roof got the worst of the hail, unsurprisingly. It was baseball and softball sized with 60mph winds... the storm made national news! Clifford held up a whole lot better than most cars for that one (August 6th 2018).
Rain gutters are all pretty good, but got some dings from the hail.
Not good... but the damage didn't result in totaling, the title is still clean.
Biggest hail dent on the whole truck. That must have been one of the softballs :(
Right rear fender well, looking back.
Right rear door.
This is the worst spot on the rain gutters, but pretty superficial.
Right rear door.
Spot under the back of the right rear door.
New-ish euro headlights, with upgraded wiring harness. Huge improvement at night!
Right front spring, front end.
Oops...
Supposedly some sort of rebuild was done at some point... no details.
Transmission cooler, made a huge improvement. Stays below 220F on the hottest of days after 80mph+ highway cruising.
