Mechanical vs electric gauge
jblueridge
Near Charlottesville, VA
In the Vdo cockpit international series og gauges I can get a mechanical gauge that reads up to 150 psi or an electric gage (and sender) that reads up to 80.
Anyone ever had a mechanical gauge's plumbing blow out?
I really like the look of the VDO gauges. Just not sure which one to get.
I use Autometer gauges but we are talking apples and apples, I use electric gauges. Even the speedo is electric. I would not be comfortable with a live oil line in the cockpit at this point, had them when younger.
I run mechanical oil and temp autometers in both trucks and never had a blowout but I've had a leaking oil tube that the olive didn't seal properly, another one I damaged and broke a oil tube in the engine bay and I've broken a temp gauge capillary tube
To me, a gauge is only as good as the probe/sending unit/etc. Ive only had autometer gauges, but their spendy... Here are the gauge sets I'm considering for my truck.
Automobile Multimeter, Dual Channel [SYL-2813] - $79.95 : auberins.com, Temperature control solutions for home and industry
I used their single channel meter for my pyrometer, mostly because it was the cheapest pyro I could find. I really like it. It fits in on the dash, and is not blindingly bright at night.
For my other gauges (oil pressure, water temperature, boost) I just used ~$20 Bosch gauges from Amazon. I went with a mechanical oil pressure gauge, which works fine, but I would probably go with an electric one next time so as not to have an oil line in the dash where it could get pinched, punctured, or worn.
I am probably going to go with the mechanical gauge. I'll use braided steel line or steel brake line for the plumbing connection.
I really like the Aubern digital guages. They have a lot of built in features including alarms and adding external lights or buzzers. Plus they are now available in the standard 52mm round bezel. Here is a pic of the Pyro and boost guage I added to my HDJ81.
I've had some crap luck with my Aubers FWIW. 2/2 now have intermittent faults internal to the gauges.
Going to be moving away from them shortly.
@AirheadNut think you could fit 4 gauges in that pod?
The gauge plate is 8.5" across the middle, my gauges are 2" with 2.25" faces, so only three will fit. With a smaller gauge, like a 1.75" or a 1.5" it would be possible, but I don't know if gauges come that small. I will be posting more detailed information and photos of the gauge plate in my build thread.
I have a CAD drawing of the face plate. I am using the dashtop OEM pod also. I am going to use angle rings to tilt the gauges towards the driver. My drawing has 3 holes that are slightly elliptical to accept a gauge turned at an angle.
I can send a copy of the drawing if anyone wants it.
Thanks for that.
The thought has crossed my mind to do a coolant temp gauge but I a don't know where to cleanly mount it with my existing gauges.
Crossing this idea off the list for my issspro gauges
