SOLD McAllen, Texas; 2000 Toyota Land Cruiser.
Year
2000
  1. 100 Series
Texas United States
Mileage
247180
247K Toyota Land Cruiser.
Color: Champagne Pearl
Clean title in my name.
Daily driver since purchased in March of 2021. Used mainly for beach trips. Great rig. Never failed me once. Tons of maintenance. Prior owner worked at Lexus dealer. Have several records of work done.
Timing belt replaced at 226,133k.
Rock Sliders: local custom shop made. Welded to frame. (April 2022)
Roof Rack: Prospeed Rack w/light bar brackets (June 2022)
Suspension: 2 inch lift, OME rear springs and torsion bars, slee diff drop, iron man pro foam cell pro shocks front and rear (Prior owner and done within 10k miles).
Wheels and Tires: Nitto ridge grapplers (315/75 R16) on KMC KM542 impact wheels (16x8). Less than 4k miles on tires (April 2023).
Denso O2 sensors - replaced 2 up stream sensors (April 2021).
Engine oil cooler replaced w/ relief value and all new hoses - OEM parts (August 2021).
Replaced Heater Ts (2), heater hoses, cam seals (2), crank shaft seal, power steering hoses and valve cover gasket (February 2022).
Bosch Icon windshield wipers (May 2022).
Auxito LED headlights 9006 (June 2022).
NGK 4589 LSR Iridium Spark Plugs (June 2022)
Battery (June 2022).
EFI Relay Bypass Kit — Immobilizer fix IH8MUD - (June 2022).
Hood struts x2 (June 2022).
Upgraded interior lighting to LEDs — doors, overhead, cargo area and license plate (June 2022).
Replaced towing module and wiring (June 2023)
Oil replaced with Mobil1 and wix filter every 3k miles.
Fumoto brass drain valve (November 2023).
Installed sound deadening mat in cargo area (November 2023).
Alternator replaced (September 2023)
Bad: Interior could use a refresh. Leather is pealing and drivers seat has large tear. Carpet has seen better days. Drivers side door lock motor needs to be replaced (low cost). Moonroof needs hose to be blown out. Surface rust is beginning to form due to salt water from beach; however, grinding wheel will knock it off.
Vehicle did have hail damage in June of 2018 and was fixed through insurance claim. There is a few very small dings still left; however, not noticeable from a foot or two away. Title is clean.
Asking $12k.
Please feel free to ask for more information or additional pictures.
