Maxline by Rapidair (2 Viewers)
Yeah about that.........
I got the lines mostly installed then jumped into a couple new vehicle projects waiting for the new machinery to get delivered and the shop is a disaster, I'll try to get a photo or three tomorrow.
Right on...if the vehicular projects happened to be in the background we wouldn’t complain either...just sayin’
:beer:
This bit that goes over the big rollup door kind of kick my butt trying to get the long pieces over and under all the other crap that was in the way.
Under the mezzanine I ran the ½” to several air chucks and added a block for the Haas that will be delivered when they get computer chips again.
Over in this corner I have lots of different air options for the various equipment over here.
I’m polishing a little intake manifold for my flat head and I’m buffing the lettering off the sidewalls on a set of rear tires when my fingers give out from sanding on the manifold, still quite a bit to do on these two cars then I’ll finish running the rest of the airline over to the lift and finally be able to cross this shop air project off my list.
For the short time I’ve had the line installed it has been great and I wish I had done something like this sooner. I’ll stop getting side tracked and finish then give an update if I find any issues but so far I’d say if you’re thinking about it the Rapidair appears to be a great solution for the money.
Appreciate taking the time to share, looking good 😎
Saw a deal and grabbed a cheap kit, been on my to do list far too long.
Will try making my own straightener with these “rollers”
And I will post up if this turns out to be total garbage.
I wish I would have tried a straightener of some sort. I just manually fought and wrestled the tubing by hand into shape.
You did lightyears better than most - they typically look like someone threw a bowl of spaghetti at the walls and ceiling.
