what is the biggest size tire u can fit on a slee ome 2.5" lift i tried searching and couldn't find anything?? oh and if anybody got some pics to show off there lifts much appreciated.. trying to figure out what i wanna do with my beast!!
How would one go about spacing down the travel to fit the 35s? Would you not have to drop the bumpstops anyway, seeing as how the main problem is the 35" tire hitting the inner fender? It seems that in theory a 2.5" lift should fit 35" tires with only additional bump stops in the rear? Suspension is not my forte, but I am interested in fitting 35"s on my medium lift as well as the OP.You will rub 35" tires if you wheel it hard and make no adjustments. First pic shows how much distance is left to the bumpstop when 35's started to rub in the rear wheels on my rig (no issues on the front at all).
Now you could easily do some spacing down of travel (or just drop your bumpstops 1.5" in the rear and lose a bit of up travel) and 35's are a no brainer, and you could fit 37's if you really messed with it and did a bit of trimming.
Second pic shows OME medium on 35's. These are Trxus MT's, which are a bit larger than some 315's, but you will still rub if you wheel it hard.
295's are a perfect size for this lift if you don't want to do anything else to it.
