material sticking from roof rails
CA
Hi, new member here, I own 2020 LX. I wanted to know if anyone have seen this felt / blue scotch brite near the roof rail before.
A tiny bit of it is stuck between the rail and the rubber. Not sure it was some shim from the factory assembly or a detailing job got it stuck there.
Thank you, that sounds very plausible. It looked more abrasive but I've not used a carwash fro a long time
I'm going to try to extract it.
@2021 LC200 You seem to be correct. It took lube and real pliers to remove but I got it out. It was quite stuck in there.
