i watched a video on youtube of the destruction.
ARB Air Locker vs Yukon Zip Locker - YouTube
(don't know if its the same one reffered to above, i just found it)
the only significant difference between the two that i see is the failure mode.
Yes, the arb held out for a few hundred more ft-lbs, but when you are in the 6000 ft-lb range, a few hundred ft-lbs equates to about a 5% difference in failure. so that may or may not be statistically significant. a larger sample size would hash that out.
However, the failure mode is what interested me. on that point i agree completely with arb. the axle should fail first. it leaves you with the most options to get home and the least spendy repair bill in my opinion. So based on just what i saw there, the arb seems like a better engineered part.
However, on the other hand, how often does your ring and pinion see 6000 ft-lbs? how often does it see half of that?
I could see
maybe in an impulse momentum type of situation where the wheel is spinning quite fast under a load and is suddenly drawn to a stop in a very short amount of time, then
maybe you could get a
spike of several thousand ft-lbs of torque in the differential (over a very short amount of time). but i dont know what the probability of that is, especially in our relatively low hp rigs. that is where i think the test arb did is...not flawed per say, but lacking.
dont get me wrong their methodology seems legit, but i just dont know how practical it is.
maybe you could do that in a high horsepower supercharged rock racing buggy making 800-1000 hp to being with, but i would be hard pressed to believe we could do it with our junk.
just my .02
