Well I'm the lucky or unlucky guy depending on how you look at it who bought Action Jackson's crawler box. This was a bigger project than I anticipated. The box doesn't fit as advertised. There is some grinding that needs to be done to make it fit US transfer cases. It's a shame because the amount of money the crawler cost it should be a simple bolt on. I can understand gas tank and floor mods those where easy but it is the other stuff that is a real pain.
I wanted to install it without a body lift and not remove the transfer case from the vehicle. I did the whole install with little to no help on a dirt driveway. Which really sucked. It took me five days to get it installed and running.
First I modified the gas tank. I got free labor from my Landlord. He was gracious enough to weld it for me as I was a little nervous doing it myself. He said there was nothing to worry about. "Just hook a car exhaust to it" Yeah ok....I just stood far away. Surprisingly nothing went BOOM!
Marking where to cut.
It's been cut...no going back now.
Cut piece
A look inside
Getting ready to weld
My landlord welding it up. No boom so it's safe. lol
Completed tank
Installed in the vehicle
So after the gas tank was done I went on to do the transfer case.
So after taking the rear extension off and splitting the case this is what you see. Input shaft removed.
Instructions tell you to grind half of the two small ribs near the splined shaft for clearance.
Interface housing needed to be modified to clear oil pump relief valve. So did the box.
Here it is installed on transfer case. With the new input shaft and gears installed.
On to the floor mods.
Here's where I had to cut and raise the floor.
Ouch! First cut no going back now. He He
Floor all cut and crawler raised into position. It comes approx. 4" into the interior. So even with a 2" bodylift I would still have to cut.
Completed floor.
Needed to cut a notch in the body crossmember to fit air valve.
Here's what it looks like mounted. Gas tank not installed.
People say this is the greatest mod you can do to an 80. I have to agree. This thing is bad ass! I love it! It works so well. I have so much more control now. It is so low I can get out and walk with it. It is so relentless on the rocks. You really can't slow it down. Although it was a pain in the rear to install it was well worth it! I love this thing!
Cut piece
A look inside
Completed tank
Completed floor.
I wonder what would be the limit of degree climb if any?
