Manual to power window conversion
So the bolt pattern on the 2 window regulators is significantly different. Power windows is much larger. Both in the front and the rear
GOOD NEWS---both power window (tan door) and the manual window (silver door) contain both bolt patterns
Red square on the tan door are the power window regulator bolt holes
Red square on the silver door are the manual window regulator bolt holes
Notice both doors contain both sets of holes
I have everything except the door panels. I might even have a set of rear blue/gray panels. I know I don't have fronts
ANYONE have a set of gray front door panels with manual window cranks? Of course it would have to match what Shes Mad has, right? AND the price would have to be right ;)
My rear panels are the narrow gray stripe.
I don't think you need anything for the locks. Power locks work fine when operated manually. Just regulators and cranks, which I have. Plus the door cards. I have the trim for that interior handle I see missing in your pics
I actually have that handle trim and a couple of spares. I just left it off after working on it the other day. So...you have only the rear panels correct? Gosh, if only someone had the front sets, I'd be set. BUT! I just realized after reading your reply about the door locks...I have an aftermarket alarm system...I NEED Tthe locks to be powered, yes? Currently they're intermittent; will all lock with the alarm fob but won't unlock with the key fob. None of them will. Will all sometimes lock when I turn the key to "ACC" but won't lock or unlock when using the Driver's side master panel.
You are on your own there. I have no idea
Yessir! 'Read this post a few times. I'm not electrical savvy at all and got lost about two sentences in. This is why I just wanted to explore the option of going manual, especially with the windows. The more I think of it though; my rig being RHD and all, my place of work being on a military base that has gate guards checking access on the LHD-side and not to mention the rare drive-thru occasions, I might have to keep the power window option. I'm a wreck.
You can do just the power door lock mod - it's a separate deal. But I see your point with the LH window and the guard gate, I had to go through that routine thousands of times over my career.
