Manifold to head gasket - dry or gasket sealer?
Cairns, Far North Queensland
Hi Guys
I'm about to pick up my 2F standard exhaust/inlet manifold from the engineer - surfaces are being trued.
I made a stainless heat shield to replace the standard vent thing from 16g st/steel - seems to work a treat.
I would like some sort of steerage as to whether I should be using the gasket dry or with some gasket sealer.
Also, does anybody know the correct torque values for the nuts/bolts.
After moving house, I've yet to locate my manual.
Thanks for all the help to date.
seal or dry
The advice I have seen seems to always be coat all 4 surfaces and use felpro gaskets if you can or OEM
I double gasket (felpro) along with high-temp silicone between each gasket....
IIRC torque 45 or thereabouts... but I tighten the dog s*** out of them.......
No problems thus-far.......
I run a header on both my F1.5 and my 2F and used no sealer, just OEM + FelPro double gaskets. No leaks on either. Retorquing is the deal breaker, just do it.;)
Ed
Stock manifold and trued your good with single gasket and sealer. Header..double and sealer....and sometimes double on the exhaust and single on intake....worked for me....
