2005 LC. 150,000 miles.
I had my oil changed two weeks ago by the dealer. I have been at home the past two weeks and have not driven it all that much. Maybe 100 miles or so. Yesterday, I noticed a burning oil smell while driving. I also noticed longer brake time when coming to a stop. I was only 1/2 mile from home so I pulled into my garage. I had oil leaking badly from the front left of the engine. I could not pinpoint the exact location, so I reached down to see if the filter was loose. It was so oily that I had a hard time turning it. It moved enough that I heard a very slight "squeak" when turning it. I checked the dipstick and I could not get a read. Thinking that the filter was loose and that I tightened it enough, I put some oil in to top off. Actually, A LOT of oil (the oil light never came on). I started the truck and I heard the oil just pouring out onto my garage floor. I jacked it up to see if I could pinpoint the leak. While removing the left front tire, there were two loose lugnuts that I could removed by hand. I could not exactly see where the leak is coming from because the entire bottom of the engine is soaked. The left side of the truck is covered in a mist of oil. It does not appear to be the drain plug.
Long story, simple question. Other than the filter being loose, what else could this be?
Thanks,
-Tim
Thanks,
-Tim
