Is this what you need, Steve? Closest I could find.
Mark W said:Having something that abrasive in my hand makes me nervous when I'm looking at a crank at the same time.
Mark...
I understood the rule of thumb to be 10 psi per 1000 rpm running and around 20 psi at idle...Poser said:Anyone know what min. oil pressure warm is? I have heard single digits...but cannot remember from who...
rgentry said:My electrical gage is so far off that it
never goes past the first bar -- that's probably part
of the reason why I gripe.
Poser said:Mark-
My statement about " wondering when this was going to start " was directed at the double entendre, not about you second-guessing me...
" a word or expression capable of two interpretations with one usually risqué "
I was surprised that there were not more crank comments...
Poser said:No, they were installed properly...ever seen a crank and bearing set that has had that happen to it??? Typically it not only takes out the bearing and the crank, but the block will need to be line bored as well....
fjwagon said:I have seen 1 bearing installed the wrong way and all the others installed correctly and it did not cause problems in the piston area.
Yep, none around here.Mark W said:I have yet to find a machinest who can line bore a 2F. Every main is a different size.
Mark...
Mark W said:You've misinterpeted the cause of you destroyed engine. A bearing can not "lock" sufficiently to do this. The bearings are too soft to instantly stop the rod rom rotating. They *will* "sieze". But that is basically melting due to insufficient lubrication. The result is a draging on the crank and a (relatively) gradual slow down. Once the rpm drops low enough the engine stalls out. A bearing can also "spin" (usually from excessive rpm) but again it is the bearing that is destroyed but it doesn't grenade the engine.. I have seen them melted from both of these type of failures to the point that they were extruded from the journal and sprayed around the crankcase. But a bearing failure will not cause the destruction of an engine at speed.
What is far more likely is that you over reved the engine, either as it came apart of not too long previously. This will stretch the rod bolts. Once this happens, the engine is just a littlebit of excitment waiting to happne.
This stretch relives the torque on the rod nuts and this will allow a rod nut to work loose and then it cascades from there. The other bolt gets stretched from the increased stress (if it wasn't already). The bolts bend and break, the cap comes off on the down strok, bounces off the pan, and winds up in the rotating assembly. At speed. THIS WILL cause the reults you describe.
I've seen this... a few times. At one time I had 4 engines here which had suffered this fate. Cool to look at if it's not your engine.
Mark...
Degnol said:OK, I have a terminology question. I had my 2F bored .030 over and they wanted the main journals when they did it. For some reason I thought that was line boring. But I understand what you guys are saying about the mains being different sizes, so "line boring" is aligning all the journals.
Was what I had done to my block Align bored? It was supposed to make sure the cylinder was centered over the right spot on the crank for the con rod.
Just set me straight. Trying to learn something here.![]()
Ed
Gumby said:I have certainly seen engines that wiped a bearing and were driven with a knock until the rod end cap was hammered off of the rod end, then the rod was smacked hard enough by the rotating crank journal to launch it through the block.
Got the rod and piston from one sitting on my file cabinet, in fact. It hit the cam so hard it busted it in four peices, which then became part of the rotating assembly as well.
Mark...
Mark W said:You've misinterpeted the cause of you destroyed engine. A bearing can not "lock" sufficiently to do this. The bearings are too soft to instantly stop the rod rom rotating. They *will* "sieze". But that is basically melting due to insufficient lubrication. .
I didn't miss that at all. It wouldn't take much more to drop the trans out of one of these, pull the timing off of it and get a look at the journals. Or at least pull the main caps and bearings off one or two at a time and spin it around to look. Suppose that this damage was caused by something that migrated through you oil system, where else did it go? How much of it was there? It's way easier now than when you get it back together and it has problems again. I'm not saying that it will, just cheap insurance to look at it now.Poser said:Guess you missed that this is inframe huh?
Mark...
