Here you go. It's a thing old Jap motorcycles guys deal with a lot. Here's a Honda Service Bulletin from 1967.
TL #27
6/8/67
CHANGE OF THREADED PARTS
IMPORTANT!
In an effort to obtain more universal uniformity of threaded parts, the J.I.S. (Japan Industrial Standards) threaded parts standards have been modified to conform with those established by I.S.O. (International Standards Organization). All Japanese industry, including Honda Motor Co., is cooperating in this change. Although the modifications of the present J.I.S. system are not extensive, this change will require some new tools, different tool applications, and will introduce the possibility of non-interchangeability of similar parts.
This change-over will be effective from the start of production of all new motorcycle models first produced after the beginning of 1967. In all other models, those previously in production, the change-over will be made gradually and on no set schedule.
The following will describe the modifications and the effect they will have at the dealer level:
- Change in Thread Form -- The minor diameter of internal threads will be decreased slightly in all sizes. This change is very minor and will not affect interchangeability in any way.
- Height of Bolt Heads -- There will be minor changes to the height (thickness) of bolt heads in several sizes. These changes will not affect interchangeability.
- Thickness of Nuts -- The thickness of both common and thin nuts will be reduced in sizes 8 mm and smaller. These changes will not affect interchangeability.
- Width Across Flats of Bolts and Nuts - - The width across the flats of the hex (the wrench size) is changed for all nuts and bolts except 6 mm.
Normal Dia.Width Across Flats (Wrench Size)
(Size of Bolt or Nut)Present J.I.S.Modified J.I.S. (I.S.O)
3 mm6 mm5.5 mm
4 mm8 mm7 mm
5 mm9 mm8 mm
6 mm10 mm10 mm
8 mm14 mm12 mm
10 mm17 mm14 mm
12 mm19 mm17 mm
14 mm21 mm19 mm
16 mm23 mm22 mm
18 mm26 mm24 mm
20 mm29 mm27 mm
New wrenches in the 5.5 mm, 7 mm, 12 mm, 22 mm, 24 mm and 27 mm sizes will be required for the modified bolts and nuts. All other sizes are currently in use.
This change in hex size affects only the wrench sizes; interchangeability of bolts and nuts is not affected.
Change in Thread Pitch -- The standard thread pitches for all bolts, nuts, and screws in the 3 mm, 4mm, 5 mm and 12 mm sizes are changed as indicated below:
Normal Dia.Thread Pitch
3 mm0.60.5
4 mm0.750.7
5 mm0.90.8
12 mm1.51.25
These changes will affect the interchangeability of threaded parts in these sizes.
Care must be taken to use the correct pitch to avoid stripping.
These changes will also require new taps and dies.
New tools, where required, will be available through parts department.
To help avoid confusion in the 3 mm, 4 mm, 5 mm and 12 mm size, wherein the thread pitch has been changed, the modified J.I.S. (I.S.0.) threaded parts used by Honda will be marked such that they can be readily identified. The marks used are as follows:
Part TypeDescription of Marking
Std. Hex BoltA number, indicating the strength of the bolt, will be embossed on the top of the bolt head. This mark will appear on modified J.I.S. (I.S.0 .) bolts of all sizes, but as explained above all sizes except 4 mm, 5 mm, and 12 mm (there are no 3 mm hex bolts) will interchange with the present J.I.S. parts.
Slotted Hex BoltThere will be a hemispherical embossment (bump) on the top of the bolt head in the 4 mm and 5 mm sizes (3 mm and 12 mm slotted hex bolts are not in use).
Cap BoltThere will be a hemispherical dimple on the side of the bolt head in the 4 mm, 5mm and 12mm sizes (3 mm not in use).
Stud BoltThere will be a hemispherical dimple or embossment on the nut end in the 5 mm and 12 mm sizes (3 mm and 4 rom studs are not in use).
All Cross Recess ScrewsThere will be a hemispherical embossment on the top of the screw head in the 3 mm, 4 mm and 5 mm sizes (12 mm not used).
All NutsThere will be a hemispherical dimple on either the top or side of the nut in all sizes with changed pitch. This will also apply to nuts that are permanently welded to other parts.
All mechanics and parts department personnel should read and understand this bulletin, to avoid confusion and damage to threaded parts when the change-over occurs.
Additional information relative to these changes part numbers, tool numbers, etc. will be published by parts department.
AMERICAN HONDA MOTOR CO., INC.
Service Department
9-325
