For Sale M416 1/4-TON MILITARY EXPO BUGOUT TRAILER WITH AIR-LIFTED ROOF TOP TENT
For sale:
M416 ¼-TON MILITARY OFF-ROAD "EXPEDITION" TRAILER WITH AIR-LIFT ROOF TOP TENT $5,200 neg.
If you have any questions or would like any more pictures, please don’t hesitate to ask. Our family size has increased, and this awesome and very functional trailer that needs a new home.
This is a simple and very functional design that you’ve probably never seen before. We built this “expedition” trailer after a lot of thought and planning. We looked at many other “Jeep,” military, and “expedition” trailers. First, we decided that we didn’t want to spend $15K-$30K on a trailer, which is what we found after studying the various trailer manufacturers’ designs. Second, we wanted a very tough and maintenance-free trailer that we could take off road. Third, we wanted something gave us options for future customization. Fourth, we wanted a true "bug out" trailer; we can keep all of our gear and more stored in the trailer, so if we do have to get out of town due to a natural disaster or emergency, then we just need to get our clothes and food and hook up the trailer and go. Last, we wanted something that will keep its resale value.
Problems with roof top tents (RTT) mounted on trailers:
We really liked the idea of a RTT on top of a smaller trailer, but we found several problems. First, if you mount your RTT on a lid, then you cannot access your trailer once you erect your RTT. This means you have to take EVERYTHING out of your trailer that you could possibly need which didn’t work for us. We get a lot of rain and wind, so this was not ideal.
Next, we look at the permanent mounted bars that elevate the RTT. The problem with this setup is that you cannot use your annex room because the RTT is not high enough off of the ground. Another problem we saw was increased wind resistance and trail clearance when you have a permanently high-mounted RTT. Having a RTT elevated all of the time really does decrease your mileage, and a higher mounted RTT really does tend to catch branches and tree limbs if you ever do drive off road.
Elevated design considerations:
We looked at many designs included fixed raised platforms, lid designs, and straight up and down struts to raise the RTT. We decided that the RTT would need to be easily raised and lowered. We looked at mechanical and electrical actuators, and after seeing several prototypes, we decided to use air.
Most everyone carries portable or onboard air, so we decided to go that route. Electrical actuators are nice, but batteries are heavy, terminals erode, wires break, and well, electrical modifications tend to get expensive and complicated.
Trailer choice:
We looked long and hard for a ¼-ton military trailer. We looked at M100s, M101s, and even the larger M1101 and M1102 Humvee trailers (they are just too tall and too big for our needs). We looked at several of the trailer manufacturers and read many cool threads on custom trailers.
While all of these could suffice, we wanted a trailer that was already proven and trail tough.
We found an original, one-owner, unmodified, unmolested, and rust-free M416 Marine Corps trailer. It’s an original Marine Corps trailer made in 10/83, and it had the military CARC (chemical agent resistant coating) applied in 03/89. If you see any “flakes” of paint on the trailer, it’s not rust from paint coming off; it’s the CARC coating. CARC is applied in layers and does peel off sometime. When the CARC does peel, you will see the original paint underneath. The CARC is painted over too in the camo pattern. Another benefit about the camouflage paint job is that if you ever do have a scratch, just pick the same color of Rustoleum paint and touch it up.
Another benefit that is often overlooked is a hand brake. Many “expo” trailers don’t have a hand brake, and when you decouple the trailer from your vehicle, you have to use wheel chocks to keep the trailer from moving. Having a hand brake makes the trailer very stable and keeps it from moving, especially if you are on uneven ground.
The M416 trailer was ready to go once hooked up, so home with us it went. More importantly, we wanted something that we could sell later should we have to move or if our family and camping situation changed.
Wheels and tires:
We first thought about replacing the wheels and tires to match those of our vehicle. Hmm… what if you change vehicles or use a different vehicle with a different hitch height? We decided to keep the original military tires and wheels. We did replace and grease all of the hubs and bearings, and we replaced both tires and tubes with new tires from Mitchell Tire (a great source for hard-to-find tires and such). We took the best of the two tires, replaced the tube, balanced it, and used this tire as a spare.
FYI, the first set of tires, if they were made when the trailer was built, lasted 34 years! The original two tires were dry rotting and could have lasted longer, but it’s just good practice to have good tires. Also, we wanted the trailer to remain stock, so the original tires looked great and actually do a great job on the pavement and on the trail.
If you are worried about trailer height or roll in a jacked-up vehicle, then you can simply do an axle spring-over. We saw several military trailers at the Overland Expo East with springovers, and the trailer owners said that they had no problems with that setup.
Trailer modifications:
All of the fabrication work was done by ACC Garage (ACC Toyota Lexus and Land Cruiser) in Atlanta, Georgia (www.accgarage.com). You can also see some of the other trailers that were the inspiration of this design at https://forum.ih8mud.com/threads/exp...-build.330173/.
1. We removed the “landing leg” which is the fold-down piece on the front that keeps the trailer tongue from hitting the ground and replaced it with a more usable crank type trailer jack (we still have all original parts).
2. We used the existing lights but switched them for 12-volt use using a standard 4-pin trailer plug (easy to put back to 24-volt if you’re a military collector)
3. We added a Toyota winch type spare tire hoist which carries a full-size spare directly under the trailer (if you don’t like a spare tire in this location, then simply remove the spare tire).
4. We added two (2) outriggers or braces in order to stabilize the trailer once you open your RTT. One of the stabilizers is on the driver’s side, and the other is at rear of the trailer. These are simple the crank type and are easy to use. Even on a trailer with a RTT mounted on the lid, you will shake your trailer a lot simply by rolling over in your sleeping bag if you don’t have any type of stabilizers. Look at any camper or popup, and you will see stabilizers used because you need them.
5. We added two (2) pneumatic cylinders in the tub in order to raise the frame that holds your RTT.
Every modification made was very minor and fully thought through. We wanted to be able to simply take the trailer back to all-original position, and we have the landing leg, original wire connector plug, and original chains that came with the trailer.
Roof Top Tent and Annex Room:
The RTT and annex room is made by IronMan4x4 of Australia. It’s a full size tent with the standard queen-size mattress layout. We are family of three, and we’ve slept with the two adults and sometimes with two adults and a child in the middle. If I remember correctly, the RTT and annex room cost us around $1,600. Here is the link: http://ironman4x4.com/products/roof-...ftop-tent-only
http://ironman4x4.com/products/roof-...ent-annex-only
The annex room is really handy and adds a LOT more utility to the RTT. You can change clothes in it, put your porta-potty in it, and we’ve even put a cot in it for extra sleeping room. We mostly always use the RTT with the annex room. It keeps your gear dry and out of the sun, and it keeps out bugs. For our family, it simply adds more room for storing our gear and gives us privacy to change clothes and such, especially if you are at an expo event or other large gathering.
The IronMan4x4 awning has a zip-in rubber floor. Many of the other RTT annex room don’t have this feature. The zip-in rubber floor keeps any rain and mud out of your tent and is super easy to zip-on and fold up when you’re done. FYI, we usually leave the annex room attached to the RTT when we fold it up for storage, but if you’re single or just want a quicker setup, then you can leave it unattached. It has a separate storage bag.
How to operate the RTT lift:
1) Simply plug in your air source to the valve on the driver’s side of the trailer. The cylinders take about 3-4 seconds of air from our air compressor. We carry a portable ARB “toolbox” compressor, and a lot of people have onboard air. If you don’t have air, as you should if you off-road or do any serious wheeling or traveling, then we highly recommend the ARB portable compressor (14 years of service with no problems).
2) Raise the tent about ½ height. This allows you to attach the wire rods that hold open the RTT window flaps. You don’t have to do this, but once the RTT is raised to its fullest height, then you may have a hard time if you’re a short person.
3) After you raise the tent to full height, and simply attach the two (2) lever latches. Although not needed, these will keep the tent frame from lowering.
4) Now you can attach the annex room. You can leave the annex room attached to the RTT, or you can run your RTT with the annex room unattached. It saves setup time if you leave it attached, but if you’re solo camping or don’t need the extra room and privacy of the annex room, then you can leave it off.
That’s it! It’s a very simple and uncomplicated setup. Please see the pictures for the RTT in various positions being elevated.
Other considerations and design features:
Fold-down built-in cooking shelves:
Notice that there are two (2) shelves that you can fold down when the RTT structure is elevated. This is just a kick-*** design that is simple and works well.
Machine cover:
Although we store the trailer in a garage, we ordered a machine cover to further protect the trailer and allow you to store it outside if needed (see pictures of lighter green cover).
Theft deterrence:
When the RTT is in the “down” position, it acts as a lid and seals and protects any trailer contents. You would have to have two or three strong guys knowing what they are doing to raise the tent structure in order to get to the trailer contents.
Tongue box:
Notice that when the RTT is folded down, it protrudes over the front of the tub. This was intentional because we wanted to have a tongue box one day. When the tent structure is folded down, it would “sit” right across the top of the tongue box. (If you do this and don’t want to fabricate or order a custome box, you can move the handbrake
Awning options:
There are standard mounting points under the RTT for an awning. We’ve used the regular pull-out awnings as well as a couple of the 270-degree awnings. Both work well and fit well on the
RTT position flexiblity:
Like any roof rack, you can position the RTT to open on the driver’s side, passenger side, or from the back. You simply unscrew the four mounting brackets under the RTT and reposition.
If you have any questions or would like any more pictures, please don’t hesitate to ask via PM. Thanks for looking :))
Pics please?
more pictures showing actual camp setup and use...
OK, this is the set of pictures showing the RTT being raised and the cooking shelves folded up and down.
more pics of spare tire, machine cover, and other things that may interest you...
Cool trailer!
Maybe I'm just not seeing it in the pictures, but how are you keeping the trailer stable (not tipping backwards) when the tent is in the fully upright and locked position? It looks like the weight is behind the axle. Just curious, glws!
Please read the description - we added two stabilizers. On is on the driver's side and one is on the rear of the trailer.
Never seen a lid. Like that! Very smart!
'Been getting a lot of PMs. Future plans included putting a box on the tongue to house some batteries and perhaps a water pump. The RTT would fold down directly on top of the tongue box adding an additional barrier against possible theft.
North Georgia above Atlanta. Someone tell me how to delete messages in the inbox. It's not full now, but I still don't see a "delete message" option. Thanks.
When the RTT is fully deployed, is there any "wiggle" in the platform?
Curious how you keep the support beams solidly anchored to the frame of the trailer.
No movement. The frame is 2" tubing with pivot points. Along with the hand brake, the two stabilizers and the front tongue jack provide stability for the trailer.
