- Thread starter
- #21
There aren't many between the LX and LC, but suspension is one of them. Just behind the running boards on the LX are the hydraulic tubes and reservoirs for the AHC suspension.no, I didn't realize there was a fit difference.
Budbuilt does not have a slider for LX570.
Yes, was an easy install for me. Did it by myself. The "hardest" part was trimming the running boards, which was easily done with a makita oscillating multi-tool.Looks great! did you install them yourself? And what did you do with the running board lights?
Are you saying the Slee sliders won't hold the weight of the rig if you pivot on a rock or do something similar? Ideally, I need something to use a hi-lift on in a pinch and lean on to overcome an obstacle. I don't plan on hard-core rock crawling, but there is always the unplanned rock or stump scenario to prepare for.
Did you trim running boards or add LC rockers?View attachment 3632890View attachment 3632892View attachment 3632894![]()
TKO. They don’t stick out too much and are good for a step. Not too noticeable or loud if you will.
Trimmed running boards. Running boards that were pretty crunched up at that.Did you trim running boards or add LC rockers?
