LX570 - Anyone Lifted? (1 Viewer)
I wonder if the front end leveling kit off a tundra will fit on an LX 570. That should give the front end a little bit of a lift.
Toyota Tundra Leveling Kit and Front End Lift Information
I am liking these:
Amazon.com: Supreme Suspensions - Tundra Lift Kit 2.5" Front Suspension Lift (Black) PRO: Automotive
07-16 Toyota Tundra Race Blue Strut Spacer Lift Kit 2WD 4WD
Says the 3" version does not fit TRD/RW Tundras, so 2" might be the way to go.
Bump.
I have these. You WILL have to modify them to fit the OE tower cups (or whateverthehell they are called)
You are running the 2" size right?
Also, what modifications were needed. Thanks.
these will not work on an ahc unless you can modify the sensors enough to think the car is at normal hieght, also be aware that on ifs set ups you require a minimum of 60mm droop for at all times.
if you do decide on these do not bother modifying tundra ones jump onto superiorengineering or snake racing and buy dedicated lc200 versions
LX570 AHC height modifications (lift it!)
This was my post. I adjusted the AHC sensors and gained about 1.25" of lift and put 34" tires on. Its easily done.
Slee and BudBuilt are soon to have sliders for LX's. There are already some LX's with the slee sliders including @Ohnoitsbreaux
my ahc is maxes out up front, could go more rear but not keen on loosing down travel. do your 34s rub and are they a true 34, im looking into some custom built sliders with lc200 panels
no rub and they're true to size.
