Having trouble with height control and AHC in general. Can't adjust heigth or change between sport and comfort mode. Anyone had this problem before??
Sounds like you have to do two things if you want to keep the AHC:... It labors to get into H, and if I load 7 people in the vehicle it drops to L, and wont even raise back to N....
...if I load 7 people in the vehicle it drops to L, and wont even raise back to N. Am I correct to conclude I need to change the pump sub assembly and o rings?
LX Pearl and Joe422, Currently the 'off' lamp is blinking constantly and the 'L' lamp is illuminated constantly. If I press the 'off' button next to the gear stick nothing happens. If I press the button to raise the vehicle the 'N' lamp illumintes momentarily then goes out. I have tried this with doors closed and park brake on and not pressure on the foot brake.
Also changing the suspension mode from comfort to sport has no effect. The suspension is currently stuck and is very, very stiff.
i have had the computer scanned by Toyota and by another mechanic. Toyota scans provided codes of c1718 and c1762 but gave no definition of the codes. The mechanic's scan gave the codes c1751 (continuous current to compressor) and c1762 (abnormal oil pressure to pump). I have had a Autoelectrician look at it. He got the pump to spin but no fluid flowed out of it. The reservoir is also overly full. I don't know if this is because all fluid has returned to the tank or because it is over filled.
Any ideas??? I have been scanning the net for a workshop manual for the LX470 2000 model. Do you guys know any links? Thanks
Thanks to All of you for your help!
I have an appointment to bring it in to a Lexus/Toyo specialist, so I'll hopefully find something more out then with that special Techstream gizmo. Agaisin thanks for that info and link! Uhu, you mentioned measuring the neutral pressure, How? and what should this be? I am not opposed to a conversion aftermarket suspension
(nice touch Brock) I just would have questions about ride quality or other safety issues, like does the AHC have any safety values regarding rollover???
Is there a particular system that works best for this vehicle, in terms of maintaining a plush on road ride and gives good stability/handling on trails? I'm not (at this point) looking for serious off roading, just the occasional off road excursion. Which actually brings me to another question... Tires and wheels. I have the stock 16" with Michelin LTX's, the tires need to be replaced, and I'm thinking about going to an 18" wheel with ???tiresAny recommendations?
Well, looks like we've all figured out the reasonable service life of AHC, 10 years.
Based on my experience converting my 99 LX to stock LC springs/tbars/shocks:
Ride Comfort:
The ride is significantly firmer with the stock LC suspension, compared to LX AHC in "Normal" or especially "Comfort" modes. The difference is most pronounced with the rear suspension.
I would not term the stock LC ride "plush". It is about as firm as my 2002 Accord now, more or less. If you like the way something like that rides, you will prefer the stock LC suspension vs. AHC. (My 19 year old son likes it.) The plush ride of the AHC entails a much higher cost ($+time) over the life of the vehicle, which is why I converted to non-AHC.
Roll Control:
Using the stock LX Stabilizer Bar with stock LC springs/tbars/shocks, the roll control seems about the same as it was with the LX, more or less.
I was concerned about this prior to converting, but I have no issues with it. It is acceptable IMO.
Keep in mind: According to the FSM, The LX AHC system is designed to couple the hydraulic pressures of the LF-to-RF, and the LR-to-RR, except when (steering angle and/or vehicle speed) are greater in a turn. At higher turn rates/accelerations, the system decouples the hydraulic pressures from each other and also varies the damping rates on-the-fly. Essentially, to improve comfort, the LX roll control is less (suspension more independent = more vehicle roll) under straight-ahead and light turning conditions, but roll control increases at higher turn rates/accelerations. Whether that actually translates into better overall roll control at higher lateral accelerations I don't know, but like I said, I don't see a significant overall difference in vehicle roll in my converted LX, and the (LX Stabilizer Bar + LC springs/tbars/shocks) combo does just fine in the vehicle roll control aspect in my opinion. I think part of that may be due to the stiffer spring rates (constant) with the LC hardware and the fact that those springs are effectively "decoupled" from one another under all conditions except for Stabilizer Bar influence.
Tinkerer,
I am planning to do the same conversion on my LX as welll using LC stock parts. Can you help me answer a few questions:
1. Do I really need to replace the LX torsion bars with the LC's? I was thinking of keeping the current torsion bars and just replacing the shocks and coil springs.
2. Did you remove the existing AHC components or just keep them in place and cap off the lines?
thanks for any help.
