1. Yes. You need to replace the torsion bars. The LC bars are larger diameter, designed to hold the load without assistance from AHC.
2. I left AHC components in place, other than the "Shocks". Yes, it is only time and work to remove them, but time is one thing I don't have enough of nowadays, and it does not hurt to leave them in place. I banded plastic bags over the ends of the hydraulic hose connections previously connected to the AHC "shocks", and positioned them where they would not interfere with anything.
1. I have heard other people using a kit from Strutmaster and just crank up the existing torsion bar after installing the front shocks to raise the height. You don't think that's going to work?
2. I plan to leave the AHC intact too. This may be a dumb question but did you have to de-pressurize (i.e, bleed/remove all fluid ) the AHC before removing the line from the shocks to avoid having the fluid squirting all over? or is not going to happen because the car is off?
