LRA Controller sorcery.
USA
What kind of sorcery is this?
Controller says the aux tank is empty and also says it is 1/2 full at the same time. (Tank is actually full).
Is the the controller going out?
Mine has had one of the middle green lights go off and on before but I’ve never experienced the Schrödinger error. I’d check for loose connections, try tapping the gauge first maybe.
Has anyone seen this behavior?
Taping the gauge had no effect or rocking the vehicle to rock the sender.
Turning the vehicle on and off same display.
When turning on it goes through a check phase, beeps, then flashed red, green-light-1, green-2, green-3, green-light-4, yellow (individually) then beeps again does the red& green display.
When the lights flash they flash one at a time, nothing combined.
I don't remember this beeping when I started the vehicle before so that is new.
Maybe it needs to re-coded? or maybe it can't remember what was coded? or Maybe it just went bad and needs to be replaced.
There is a back door to code these, so you can turn on the automatic re-fueling, but Id' have to look it up and can't remember at the moment what the resistance settings were. (auto refueling is when your main tanks drops to 1/4 this automatically turns on and then turns off when either the main goes to 3/4 full or the aux gets the red empty light). This is controlled by the black and white wire.
Look here for clues! Seems like you are in test mode. I think you are getting too much resistance on sender line 1.
Thanks !!
Looks like I have a bad ground on the black wire and it went into the test mode like you said. I'll check it on the weekend.
I do want to hook the white/black to the Main Fuel sender which should be one of the wires going into the consol.
Does anyone know which plug and pin number on the console is the fuel sender?
It would be nice to have it run automatically.
Looks like it needs 1 to 2 volts to turn on and 3 to 4 volts to turn off.
Thanks !!
I think this is a great idea. Please post if you figure out a way :)
