This makes me wonder what feedback system the ecu has to tell when the CC is saturated. It’s simple to put it on a timer and let purging happen when it thinks it should need it, but surely there is some system to tell the ecu and trigger a code if the CC gets overwhelmed.Thanks for confirming @grinchy
So the question remains why the OP is experiencing this issue. The stock setup is no different in that the charcoal canister breather is open to atmosphere.
@clearmysix , are you having any fill issues? Any CELs? Or have you had any issues in the past? Wondering if your charcoal canister is fouled in some way and saturated with fuel. It probably is by the smell issue, which leads me to...
Possibility that the evap system is not working right in some way as it should be regularly purging to "recharge" the canister by vacuuming the fumes into the intake system. It's wholly possible something in the line, vacuum switching valve (VSV), or electrical plug/harness is damaged causing that not to happen.
Actually this may be what is happening with the Moab code..
Also, you guys with LRAs have significantly increased the surface area of the fuel in the tanks, which is correlated with increased rate of evaporation. At some point the CC may not be designed to handle that volume of vapor. Then again plenty of people run LRA without issue.
Is there any correlation with LRA fuel vapor smell in places with higher ambient temperatures, seasonal, etc?
