Checked my EGR system as per Emission Control Manual and found everything working properly, EGR modulator and EGR valve checked out fine. I did find a cut vacuum hose cut, the piece that connects between the top of the modulator and the top of the EGR valve. Replaced with a new one.
Waiting for a used, checked-out OEM catalytic converter from Cruiser Parts. I paid 487.00 incl. shipping, instead of going with an new, aftermarket cat. I feel more comfortable with the used OEM unit, although it was more expensive.
When I receive the unit and have it installed, I will have it re-smog-ed. But I will re-check my mixture screw setting to get it to run less lean.
I want to get it below 14.7 : 1 on my air/fuel ratio gage... I am curious, if those readings are any better, once I have installed the replacement cat, and before adjusting the mixture screw.
In the meantime, I will check the EGR system again, to be sure and also check the AI system, per manual. I did buy and installed a rebuild air pump (OEM not Caldone non OEM style)...
