Fixed all emission related issues, as far as I know.
1. No vacuum at distributor was caused by a faulty BVSV (1), pink sensor at the thermostat housing. Dealer had one in stock ($ 63.00 + tx. !). Installed, now have vacuum at distributor when engine coolant is above 111 degrees F , zero at idle, max at 2500 RPM)
2. Installed the hot air hose at the air cleaner to exhaust manifold. (Napa- not the right size, 2" I.D., should be 2 1/16" I.D. But I made it work) See pic's.
Hope that will be acceptable to the Smog Shop.
3. Removed the idle mixture adjustment plug and checked the setting of the adj, screw. Was set to approx 2 turns out.
I will double check the idle mixture, RPM and timing again tomorrow morning, before I take the car in for the smog check.
Hope it will pass this time. I installed a temp air/fuel mixture gage to check the mixture. Cant get the stoichiometric ratio (14.7 : 1)
at idle, its more than 18 - maxed out on my gage. When running the engine at higher RPM, or while driving, it settles around 15 :1.
So I know its good, but still needs help at idle. I think, they check emission at a certain RPM....
Hope I will get it better at idle, before smog-ing it tomorrow PM.
